Dashboard lights engine abs tyre air on 2006 Prius hybrid
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by angela fahey, Feb 23, 2022.
  1. angela fahey
    angela fahey New Member
    Ireland
    How to I get to turn them off myself I have tried the ODS method but not successful
  2. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Welcome to PriusChat!!
    Better to know why the displayed warning lights are on, just use a toyota hybrid compatible scanner to retrieve the stored OBD2 codes.
    FYI : you're moderated until you've posted 5 times.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    3,454
    1,502
    NJ-USA
    The TPMS light can turn on if pressure in one of the tires is 80% or less of what it should be.
    The light can also turn on (usually flashes some then stays on steady) if there is a fault with the TPMS system. 99% of the time that fault is a sensor fault- dead sensor/battery, sensor ID not programmed into the ecu, or incorrect sensor.
    It really helps to have a capable scantool that can talk to the TPMS system as well as a TPMS tool that can wirelessly "ping" the sensors to check function and ID numbers.
  4. angela fahey
    Ireland
    SFO likes this.
