Dashboard lights not on when car is running
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Luv2travel, Dec 19, 2013.
  1. Luv2travel
    Luv2travel Junior Member
    NYC
    My 2012 Prius v dashboard lights no longer are turning on. They light up at initial start-up, but then all but a few icons on the far left and far right of the screen go out. This happened right after I played with the heat / AC controls. Any suggestions on problem and remedy? Thank you in advance.
    49,492
    is the dimmer switch all the way down?
  3. JasonW
    JasonW Junior Member
    30
    Texas : Austin Area
    Do you have something on the dashboard that's covering up the small black light sensor? If so, that can cause the interior lights to dim considerably.
    49,492
    have you checked the fuse?
  5. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    Do you mean the HSD display has disappeared ?
    There is an option to turn off various bits of the HSD display, when you cycle through the various display options by pressing the display button on the steering wheel you will see a "SET" option. Hold the display button down for a couple of seconds and the various options of the HSD display can be selected, one of them turns it all off.
  6. bisco
    49,492
    have you put black tape over all the displays and forgotten to remove it?
