Dashboard lights & warning symbols
Discussion in 'Newbie Forum' started by My Number, Aug 8, 2017.
  1. My Number
    My Number Junior Member
    London
    Hello everyone
    My 2012 Prius battery in boot died, I replaced with new battery, car starts up drives but all dashboard light are on abs, air bag, power steering light, triangle warning,.
    Also gears on dashboard do not show as moving from park to neutral to drive or reverse, but physically the car drives, reverses etc only on dashboard it doesn't indicate when you move the gears ???
    Anyone know what is reason for this
    Appreciate any solutions
    Thanks
    51,154
    welcome!
    not sure, but it might be worth testing the 12v, and connections, especially neg to ground.
    RCO likes this.
  3. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    are you sure the new battery is fully charged?
    RCO likes this.
  4. My Number
    London
    Hello
    thanks for the responses, sorry for delay
    I managed to test battery it was 12.50 volts with car engine off, it was 13.83 with car engine on
    new battery specifications are:
    • Amp Hours: (ah)40AH
    • Cold Cranking Amps: (CCA)300CCA
    • Length: 187mm
    • Width: 127mm
    • Height: 226mm
    if thats any help, battery looks kind small
  5. bisco
    51,154
    it is a small battery. how long had the car been off when you measured it?
    even 12.5 is low for a new battery, but serviceable.
    RCO likes this.
  6. My Number
    London
    the car had been off battery connection for 7 days straight before i reconnected and tested it
  7. bisco
    51,154
    put a charge on it, and see where it winds up. should be around 13 v.
    RCO likes this.
  8. My Number
    London
    I forgot to mention the window controller for all windows on drivers side doesn't work except for driver side window.
    And remote fob doesn't work I changed fob battery but still not opening or locking doors by the remote fob :(
  9. frodoz737
    frodoz737 Top Wrench
    4,535
    2,438
    33
    Arm chair guess...there are 2 fuse-able links on your positive battery terminal "connector" that might be worth a look. Short of that and what was already offered, get the DTC code pulled because something's not talking...or forgot.
    RCO likes this.
