Dashboard lights won't come off
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Nasser4d, Nov 13, 2018.
  1. Nasser4d
    Nasser4d New Member
    I'm going to try to make this as short as possible and I'm pretty sure many people have gone through the same issue.
    I just quite couldn't find the answers on this blog so if you guys could be nice and refer me to some answers "links"
    Or just a brief answer based on your best judgment
    I recently changed the clockspring on my 2010 toyota prius because the music volume up and down did not work.
    Everything was fine before I do that but after I had the airbag and the traction control lights on and I couldn't fix it
    My obd2 doesn't read any faults.
    The car drives smooth and perfect
    The battery charge perfect
    I will try to add pictures. I am not sure if I could upload on this blog
    Is my first post
    And please let's make this topic as short and brief as possible
    Thank you everyone
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Put your old one back in
    49,504
    welcome!
    did you use an oem spring? aftermarket are iffy
  4. Grit
    Grit Senior Member
    6,148
    4,058
    Wilkes Land
    There's a video on the forum showing how to take dashboard off, lights will be access to come off.
    Eddy Connelly and Nasser4d like this.
  5. Nasser4d
    Nasser4d New Member
    That is good idea, this is why I made my post on this blog
    Thanks man
  6. Nasser4d
    Nasser4d New Member
    Yes, it sure was for an older model but I tested fit and it was working perfect
    I got it for $20 from a jankyard
