Dashboard speedometer shakes/bounce on rough roads
Discussion in 'Gen 2 Prius Main Forum' started by amjohnson, Apr 26, 2016.
  1. amjohnson
    amjohnson Junior Member
    77
    US
    I just recently purchased a 2008 Toyota Prius with 60,000 miles on it upon driving it home from the dealer I was on a rather rough road as I was driving the speedometer was bouncing along with the dash in the back kind of Where the Hood goes over the speedometer it was rather annoying because the numbers were bouncing as you were trying to look at it not changing speed just vibrating or bouncing I was wondering if anybody can tell me if they have this problem or if I should take it back to the dealer to see if they can tighten something up when I was pushing on the dash everything seems to be tight or is there a fix?
  2. JC91006
    16,674
    8,519
    Definitely bring it back. Has this car been in an accident?
    SM-N900P ?
  3. amjohnson
    77
    US
    51,155
    congrats and welcome! def take it back and make them fix it, never herd of that before. all the best!(y)
  5. amjohnson
    77
    US
    Ok after drive a it alot more and watching the dash it is that back of the dash by the speedometer it seem to be more in the middle and makes it look like the the speedometer it bounces on rough road or seem in the road. I took it back they said it is normal all 2004-2009 do it is there a fix it is annoying see your speedometer vibrate/shake/bounce minnesota roads aren't smooth very often. Could I put something in the front defrost vent under the dash to tight it up?
