Dashboard warning sign
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Lauvin, Feb 20, 2019.
  1. Lauvin
    Lauvin New Member
    Mauritius
    2012 Aqua
    Since two days am receiving this dash board warning sign.please help.what should i do and what is the main cause of this warning
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,980
    4,724
    Texas Hill Country
    That symbol is not on US Prius c models which are essentially the same but do have different instrument panels. An aqua owners manual would tell you but I would guess its the Maintenance Required light (oil change, etc) or maybe the Check Engine light (something is wrong). A local dealer or good mechanic could verify which one if you don’t have the manual. I looked for one but only found a Japanese language version.
    It requires a scanner tool to determine what a check engine light means. If it is continously flashing it is serious and should not be driven.
    Typical check engine issues:
    1. Bad O2 Sensor Needs to Be Replaced
    2. Loose, Damaged or Missing Gas Cap
    3. Bad Catalytic Converter
    4. Bad Mass Airflow Sensor Needs to Be Replaced
    5. Bad Spark Plugs or Spark Plug Wires
    49,507
    welcome!
    agreed. likely a maintenance reminder for tire rotation and etc. should be in your owners manual
