Dashcam and Subaru Homelink Mirror Install - 2015 Prius THREE
Discussion in 'Gen 3 Prius Accessories and Modifications' started by E46Prius, Aug 9, 2015.
  1. E46Prius
    E46Prius Active Member
    314
    218
    Costa Mesa
    Hi guys. I've never made my formal introduction before. I just got a brand new 2015 Prius three. I have put 700 miles on it so far. I love the car. My other car is a BMW 3-Series manual. I loved the BMW as I put lots of money into the suspension and other mods but since I moved away from the canyon roads where I loved to drive it, it's rarely put to good use. I come from a history of BMWs and they've all been of stellar reliability. Over half a million total actual driving miles between them and not a single breakdown. But it's time for a change. I'll get a BMW convertible one day as a second joy/fun car but I only have space and time for one car right now. So I bought a Prius for my commuter/pleasure car and I am very happy.
    I plan to keep it mostly stock as I want to retain the full 50mpg rating. Any mods I do will be functional and for tech/fun reasons. I planned on getting Prius 17s and still might do it, but for now, the stock black wheels do fine for now. The less I can spend the better.
    So my first real "mod" or addition (besides pulling the stock wheel caps and installing full LED interior kit) was to add a dash cam. I didn't want to just stick it on the window and plug it into the cigarette lighter, so I hardwired it. Couldn't really find detailed information online. Information was scattered and inconsistent. So I decided to probe with the multimeter and dig around.
    For the dash cam, I chose the Mobius Action Cam. This cam gets great reviews and is super compact. It records 720p or 1080p video at 60/30 fps, respectively. It also does time lapse pictures. I have a 32gb micro sd card installed in mine and it will record about 5-7 hours of video. It simply records over the oldest video. You can also write protect a file while driving by simply tapping a button. You'll want to order the helmet cam mount for an extra stealthy/tidy install. You'll also need to buy the optional super capacitor so when the car shuts down, the video recording can properly stop when switched 12V power is turned off.
    You'll also need a 12V to 5V DC converter. (Unless you can source 5V somewhere in your Prius) I tucked this above the map light area and sourced 12V switched from the cigarette lighter port. I soldered and wrapped a wire at the port then ran it towards the drivers side and up the A- pillar and to the map light area. I then spliced it into the input of the 12V to 5V converter. I ran ground to the black/white stripe wire of the map light 20-pin harness which is ground. (Use a meter to be sure). Double and triple wrap in heat shrink tubing and electrical wrap to make sure everything is tidy. Zip tie loose wires so they don't move and fray on sharp metal edges. The total cost for this was $150.
    I will post a sample video below of when it was installed in my BMW. This can come in handy if someone does something to you on the road. The video will include everything you need to buy for this install and I'll include that same info here too.
    List of parts you will need:
    Mobius action cam
    DROK 12V to 5V DC converter
    Super capacitor
    Bicycle helmet Mobius action cam mount
    Right angle mini USB cord
    32GB Micro SD card
    My next mod:
    2014 Subaru Forester Homelink Mirror.
    I got it for $49 on eBay. Ran switched 12V (spliced from the wire I ran to the action cam) and constant 12V from the map light red wire. (Make sure you run a meter to it to ensure constant 12V) and spliced the map light ground I used for the action cam. The mirror works perfectly! Looks super cool and premium. The same or similar mirror runs for $300 from your Toyota dealer. Similar mirrors w/ a compass on eBay are the same price. Mine doesnt have a compass but I'm fine w/ that. This mirror was super cheap. It's manufactured by Gentex which is the same manufacturer that makes the Prius mirrors and pretty much all Japanese premium mirrors. Some American makes too. Way better than the stock dinky mirror that it comes with. It looks so cheap. If anyone is interested in the required pin out for a 10-pin Gentex mirror, PM me. Basically the bottom row is what you'll use. The left most pin is constant 12V, the middle pin is ground, the last pin on the bottom is switched 12V. The harnesses sell for $15 on eBay but I decided to solder the wires in to save money. I wrapped them in heat shrink and electrical tape. I have a wire cover on the way but I don't think I'll use it.
    Coming soon (a week or two) Lexus HID retrofit.
    #1 E46Prius, Aug 9, 2015
  2. Boston Jim
    Boston Jim Active Member
    202
    148
    Hi E46Prius,
    Nice job on the mods, just curious, did you tap a fuse or use an inline fuse anywhere for the camera?
    Since I had the home link mirror it was much easier for me to tap into that but I ended up using an inline fuse.
    Hardwired Dashcam to HomeLink Mirror | PriusChat
    How do you like the mobius? It looks like a really nice small cam.
    BigBear2010 likes this.
  3. E46Prius
    314
    218
    Costa Mesa
    Thanks Boston Jim. The circuits I tapped are already fused by Toyota so I figure any overdraw will blow the existing fuse. If I am wrong, you all can correct me. I'm new to the Prius.
    I love the Mobius. It's small and compact and works reliably. It runs any time the ignition is on. So whenever the car is on.
    49,371
    great install, thanks! all the best with your new prius.(y)
  5. ncases
    ncases Senior Member
    609
    672
    Chicago
    Just curiouschow did you hook the mirror holder? Is the subaru is the same wth prius mirror holder
  6. E46Prius
    314
    218
    Costa Mesa
    The holder was a direct fit. It has a screw you tighten to lock it in. I am not sure if it uses a spring as the mirror I receive did not have a spring. Either way the mirror is rock solid on the windshield after tightening the screw down.
    To update: I did order the Gentex 10-pin harness so I can have the install look a bit tidier. I broke down and spent the $15
    And the mirror works great still =) I love the range of the opener. It auto dims nicely at night. A cool blue tint
    Great! I have my auto dimming mirrors with compass taken out from my 2009 subaru tribeca I will try maybe it will fit. So where did you tap the 3rd wire(switch)
    I wrote that in my thread but I'll help you out. I tapped the cig lighter port down below in the center console for switched 12V. So I had to run wire across the knee area of the driver and up the A pillar. I did it very discreetly and neatly!
    Just installed mine taken from my subaru and need your expertise regarding the wiring. Thanks in advance. image.jpg image.jpg
    My wire harness was a 10-pin. You might want to do a little research on your particular mirror number (should be stamped on the back of your mirror) and see if you can find schematics. Looks like yours should be a simple switched 12V, constant 12V, and ground arrangement.
    If you still need help, post the model # of your mirror here.
    You can also research the forums for your particular car the mirror came from and those people likely will be able to identify the harness. You can also enter that info in eBay and eBay can sometimes have wiring pinouts. There's several ways to find the info you are looking for.
    Thanks bro. I was able to figure it out after a few taps. Black/white is the constant 12 v and the black center one is the ground. The last black wire did not use it.
    Is the mirror auto dimming? I think the switched 12V is so the mirror doesnt auto dim when the car is off and use unnecessary energy. I'd make sure if i were you
    Yes it does. Tapped it to the cigarette light 12v source. 3rd wire is just a dummy.
    Oh ok you mentioned you tapped constant 12V which is incorrect if you tapped the cig lighter. Should be switched. Also I see a wire peaking out of your passenger side a-pillar cover. and the trim/seal is loose as well. might want to clean that up. especially so you don't short any wires out. The way you have it routed looks like the wire is running in front of the airbag. no bueno. Make sure the wire is routed carefully above the airbag and zip tied out of the way. There's a harness you can zip tie it to so its not in the way of the curtain airbag.
    ncases likes this.
