Day/night driving
Discussion in 'Gen 2 Prius Fuel Economy' started by bkmcae, Nov 18, 2005.
  1. bkmcae
    bkmcae New Member
    Sorry if this has been addressed elsewhere, but I can't find it.
    I seem to get better gas mileage during the day than at night.
    I've noticed this on three separate trips. On each one I drove about 100 miles at night, averaged about 52 MPG. Return trip during the day, averaged about 58 MPG.
    I realize the outside temperature has something to do with it, but does 4-8 degrees Fahrenheit really make that big of an impact? On each occasion my day temperature was in the low to mid 70s and night temperature in the high 60s.
  2. GreenMachine
    GreenMachine New Member
    760
    Vermont, USA
    Is the destination at a higher altitude by any chance?
  3. aaf709
    3,862
    2022 Prius Prime
    That can happen. I get better mileage going from work (during the night) than going to work (during the day). One big reason is that work is at a higher elevation. That and there's more stop and go driving on the way home too.
  4. bkmcae
    bkmcae New Member
    Would love to give you exact elevations, but wikipedia is down.
    On 1 trip yes - Richmond to Roanoke is an uphill drive
    On the other 2, no not much - Richmond to Fairfax
    All points are in Virginia
  5. Kiloran
    Kiloran New Member
    1,225
    I'd bet the temperature difference is a lot bigger under the hood of a car resting in sunlight and after dark.
  6. tbstout2
    tbstout2 Member
    156
    Hallieford, VA
  7. tbstout2
    tbstout2 Member
    156
    Hallieford, VA
    FYI... I commute from Fredericksburg to Springfield every day. Since the time change, and cooler weather, my avergae tank went from 54 MPG to 50.5 MPG.
    There are two reasons, so I think: 1) I now have to drive with the lights on on my return trip (and that takes more gas to recharge the battery) and 2) the temperaure has dropped.
  8. 200Volts
    200Volts Member
    429
    43
    Northern CA
    My guess is that the colder night air is denser and thus creates more wind resistance. Ever notice how drag racers go faster at Denver then at sea level?
    Colder air also allows for more horsepower (not a big concern with the Prius).
  9. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    I have to say now that it is dark in the morning I am not doing as well. I do not think it is temperature, because my homeward commute is generally at the high of the day, such as it is. I think that when it is dark out it is harder to drive, you are concentrating more on the road and less on the MFD, and pulse and guide. I hope that it can become more automatic, but I am somewhat new to the pulse and guide thing because of two numb feet from back surgery. I am getting better and better but it is not automatic, I need the visual feedback from the MFD. When I need to mind the road in the dark the MFD goes out the window. Oh Well. I will keep practicing.
