Daytime Headlights
Discussion in 'Gen 3 Prius Main Forum' started by Tickwood, Nov 28, 2009.
  1. Tickwood
    Tickwood Active Member
    334
    101
    San Diego
    2020 Prius Prime
    On my 2004 I kept the headlights on at all times. With the dimmer switch turned all the way up I was able to see the instrument panel fine.
    On the 2010 the instrument panel is, for all practical purposes, blacked out when the headlights are on. Today it is dark and cloudy and it is raining. I want to be able to keep my headlights on but I can’t.
    Is there a solution?
  2. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    The dimmer switch has to be turned all the way until it clicks, that makes the display stay full bright, same as when the headlights are off.
  3. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    Paradox is absolutely correct...rotate the wheel until it "clicks" and you should have FULL BRIGHTNESS...
    And your lights should turn off, 30 Seconds after you leave the vehicle...(unless you changed the default setting) via the dealership.
    When you restart, they will be on once again...;)
  4. Tideland Prius
    16,445
    Yup. Do exactly as you did on your 2004.
  5. RodJo
    RodJo Member
    423
    56
    Boston
    As discussed in another thread, the dimmer switch changes the display abruptly from dim to off -- before it's turned all the way down. To see the display (day or night) your dimmer needs to be turned up.
  6. Tickwood
    334
    101
    San Diego
    2020 Prius Prime
    Many thanks, somehow I was unaware of the extra click available. All OK now.
    Thanks again
