Daytime Runjing Lights??
Discussion in 'Prius v Main Forum' started by B-52, Jun 2, 2013.
  1. B-52
    B-52 New Member
    16
    Jersey Shore
    Just noticed on my Wife's 2013 there are no daytime running lights, that are always on even when headlights are switched off or on auto.......I was under the impression most, if not all newer cars were equipped....
  2. -1-
    -1- Don
    1,247
    434
    Chester, Virginia
    :)No DRLs on the Prius V, model 5. Here's a LINK.
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    If she just leaves the headlights on, they will default to delaying 30 seconds to turn off after you stop the car and then open the driver's door.
    You can change that to 60 or 90 seconds or turn off the delay to get 0 seconds.
    http://www.toyota.com/t3Portal/document/om/OM47674U/pdf/sec_06-02.pdf
    (page 3 of the PDF, page 525 of the manual)
    The light sensor on the dash still controls dash lighting on the v, so you do not need to mess with that.
  4. Alan Stoddart
    Alan Stoddart Junior Member
    27
    DRL's are required in Canada, not so in the U.S., I think.
  5. Delta Flyer II
    Delta Flyer II Active Member
    547
    248
    69
    Some US versions have the ability to choose to have them on or off... Mine I can program on or off, Prius C has it on the stalk DRL off
  6. mikefocke
    3,692
    1,644
    Sanford, NC
    Look up Toyota Part 00016-47021 Accessory Code: LDBO10 distributed by SouthEast Toyota Distributors
