Daytime running lamps
Discussion in 'Prius v Accessories and Modifications' started by 2013-Prius v, May 24, 2013.
  1. 2013-Prius v
    2013-Prius v 2013 Prius v 5
    198
    39
    Orange County, CA
    2013 Prius v wagon
    Is it possible to cover the sensor (not sure where its located) to trick it into thinking its night thus resulting in lights on? Kind of like when you enter a tunnel & your driving lights turn on.
    iPhone ?
  2. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    Would it not be easier if you just leave your lights turned on all the time?
    matt b. likes this.
  3. 2013-Prius v
    198
    39
    Orange County, CA
    2013 Prius v wagon
    Until you forget to turn them on/off. In auto setting, they turn on automatically when dark.
    iPhone ?
  4. ImeanGreen
    547
    73
    Somewhere out there
    Keep it turned on. It shuts off automatically after 30 sec(depends on how you program your shut off time). When you start the car, it turns on automatically. No need of reminders unless you turned off your headlights. In auto setting, your headlights are off during day time. If you cover the sensor, you will be adjusting the dash lights during day time because it's too dim. At night, it will be too bright if you adjust the dimmer switch to suit your daytime driving.. This will be the same problem when you turn your lights on all the time to serve as DRL's.
  5. 2013-Prius v
    198
    39
    Orange County, CA
    2013 Prius v wagon
    I love this forum. Learn something every day. Ok, was not aware that lights turn off by themselves.
    iPhone ?
  6. JimboPalmer
    12,470
    6,870
    Greenwood MS USA
    They do unless you open the drivers door before you turn off the car
  7. Chazz8
    Chazz8 Gadget Lover
    744
    234
    61
    Central New York
    I thought the only way to get the headlights to stay on (forever) was to not open the driver's door after turning Prius off. Like when I jump in the passenger side to test something I read here on PC, then power off and exit via passenger door. Some time later I saw the headlight still on and squeezed over to drivers door to open/close it and headlights went off.
  8. Peter Klein
    Peter Klein Junior Member
    2014 Prius v wagon
    My 2012 V3 does not seem to have auto headlights. If I leave the lights on when turning off the engine, I get a warning sound when I open the driver's door. My headlight wand only has 3 positions: off; parking lights; and headlights. None of the drawings in the manual match my wand. Do I have something wrong?
  9. JimboPalmer
    12,470
    6,870
    Greenwood MS USA
    I can only speak to the Prius v Three in the US.
    By default if you turn the car off, THEN open the driver's side door, it will turn off the headlights in 30 seconds.
    I had 0 seconds on my Gen 2 and liked that, so I turned off the delay.
  10. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    Peter: My 2012 II has daytime running lights.....I thought that all 2012 Prius has them now.
  11. radiocat101
    radiocat101 New Member
    you get an insurance discount for cars with DRL
