Daytime Running Lights
Discussion in 'Gen 2 Prius Main Forum' started by Harper, Mar 7, 2005.
  1. Harper
    Harper New Member
    60
    Fountain Valley, Ca.
    Hello Everyone-
    Sorry if this question has been asked before, but, I've just discovered this website today, March 7, 2005. Does the 2005 Prius, Package 6, have Daytime Running Lights? If not, is it harmful for me to just leave the lights engaged and the power off of the vehicle without damaging anything like the battery or Hybrid system? Great website, by the way. It's just what I've been looking for.....
    Harper
  2. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    <div class='quotetop'>QUOTE(Harper\";p=\"70410)</div>
    Welcome!
    No harm. When you turn the car off, then open the door, the lights go out. When you start the car next time the lights will come on.
    I leave them on all the time for safety.
    No USA Prius model has DRL.
    And here are two more PriusChat points to double your score to four. :wink:
  3. Harper
    Harper New Member
    60
    Hey, thanks for your reply, Patrick. So, I take it I do not have DRL?
  4. Sufferin' Prius Envy
    3,998
    No USA model. So if your car fits that description . . . no.
    And I believe no HIDs have DRL either.
  5. Tideland Prius
    16,445
    nope, that's why we didn't get the HID option because of our DRLs.
  6. arubinst
    arubinst Junior Member
    Lausanne
    Hello,
    is this true for the European Prius as well?
    <div class='quotetop'>QUOTE(Sufferin' Prius Envy\";p=\"70412)</div>
    I'm in Switzerland. I received my Prius 5 days ago. When I turn the car off and open the door, the car starts beeping until I shut the lights off (they remain on). I must confess that I have not tried to close the door and see if the lights go out, but I have the feeling they wont.
    Thanks for any comments. I enjoy reading this page very much.
    Abraham
  7. duanerw
    duanerw senior member
    140
    lexington ky
    2013 Prius v wagon
    Hi I was lucky to find my2005 prius 130 miles away and in stock.drove there,picked it up and drove home.He was the only dealer that would give me my wifes toyota emply discount.
    on the way home in the daylight i turned on my headlights by habit.and got 42 mpg.i thought about it a couple days later and felt leaving the lights on in the daytime i was running down the batt. and causing the ice to run more ofter.dont know if im right or wrong but i dont turn the lights on in the daytime anymore.
  8. KTPhil
    KTPhil Active Member
    1,379
    Neglibible mileage penalty for headlights. The HIDs use about half the power of halogens, so they are even less of a drag.
  9. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Well, as stated the Canadian market Prius *does* have DRL. They turn on at somewhat lower intensity than regular low beam, so the bulb life isn't impacted that much.
    My 1990 4Runner appeared to use the Swedish method of DRL: once it started *all* the running lights came on. I became quite handy at replacing the sealed beam headlights: this was something that required removal of the grille, so it *was* a big deal. Also running lamps too.
    Although there will be a negligible impact on MPG by driving around with the headlights to On all the time, be prepared to replace headlight bulbs and running bulbs more often.
  10. KMO
    KMO Senior Member
    1,825
    599
    Finland
    2023 Prius Prime
    Abraham,
    The European Prius cuts out the headlights when you turn off, but leaves the sidelights on. You can reactivate the headlights by turning the switch all the way to off then back on again.
