deactivate start button -car symbol still blinks
Discussion in 'Gen 2 Prius Technical Discussion' started by aspens3, Oct 18, 2012.
  1. aspens3
    aspens3 Junior Member
    25
    Alaska
    I'm parking the car (gen. 2) a long while, so I checked the manual which shows the deactivation button on/off positions. It show the button sticking out more = the off position. However, the car symbol still blinks on the dashboard.
  2. nh7o
    nh7o Off grid since 1980
    1,686
    338
    Hawaii
    I assume that is the SKS button that you refer to, that turns off the SKS system. The blinky light will still be there, as it is a function of the vehicle immobilizer which is always active. The light will go off when you insert the key fob into the dash, as in a non-SKS type car. It's current consumption is minimal.
    If you leave the car for a long period, you will want to be sure of the quality and charge of your 12V battery to insure a reliable start.
  3. Patrick Wong
    18,200
    6,474
    What does "long while" mean?
    If more than a month, you should first charge up the 12V battery using a battery charger - then disconnect the negative cable where it attaches to the body.
