Deactivating seat heater switches in Prime, help!
Discussion in 'Prime Main Forum (2017-2022)' started by Downrange, Aug 22, 2023.
  1. Downrange
    Downrange Active Member
    360
    189
    2024 Prius Prime
    SE
    I keep turning on my seat heaters with my water bottle. I really would like to deactivate them for summer use. Not sure whether it's a simple fuse pull, or need to unplug under the seat. Anyone done this?
    49,490
    i haven't, but i would certainly look for a fuse first
    Downrange likes this.
  3. road2cycle
    road2cycle Active Member
    168
    109
    Sonoma County, CA
    Another solution would be to use the rearmost cup holder for your water bottle if it’s only you using the front cup holders. But as mentioned above there is a fuse for each front seat that you you can pull.
