deactivating theft deterrent system
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by priusunum, Jan 6, 2008.
  1. priusunum
    priusunum priusunum
    Virginia
    My 2006 Prius is a great car, but I've developed an intermittent problem lately: for no apparent reason, the theft deterrent system will act as though someone is trying to break into the car when there's no problem at all. Last night it happened while the car was alone, unlocked, and parked in my closed garage. I had to run down two flights of stairs in my pyjamas to the tune of a blaring carhorn and come into the garage to see the headlights flashing on and off and turn off the alarm. It's a real pain.
    Has anyone else had this problem and if so, how did you solve it? I haven't seen this issue addressed on Prius Chat. I looked in my Prius manual and it says the dealer can deactivate the theft deterrent system if so desired. I live in a small town and keep the car garaged, so I'm thinking that might be a good solution. Other than reducing the theft protection, is there any downside to doing this? Is it a simple procedure? Does it cost much?
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Make sure you didn't accidentally activate the panic button on the fob. If that's not the case, check your 12V battery. A low 12V battery has been known to cause odd activation of the alarm.
    Tom
  3. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    all doors must be LOCKED before the theft deterrent system activates
    it will not activate if the doors are UNLOCKED
    so that rules out the alarm, yeah so make sure someone didnt hit the panic button
    permantly Deactivating/activating isnt something trivial you can do, the only way to do that
    is for the dealer to use his toyota scan tool
  4. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    I've managed to sit on my own panic button on occasion. If the
    fob takes a beating in your pocket, the button pad inside it
    could begin to go flakey. Try this experiment: open up the fob
    and take the battery out, and forgo use of smartkey or the
    remote clicker for a few days. See if it still false-triggers.
    You may also have an alternate fob [in better shape?] you could
    use for a while.
    _H*
  5. priusunum
    priusunum priusunum
    Virginia
    Thanks to those who replied! It looks like I must have accidentally pressed the panic button in my pocket to activate the alarm. I tested out the possibility of pressing the panic button from my top floor (three floors up from the garage level) and it did start the horn blowing! And yet the manual says the keypad on the fob works within three feet of the vehicle...
    I phoned the dealer who told me it would cost me $79 to have them deactivate the system, which they said takes about an hour or an hour and a half to do. It's not covered by the warranty so I'd have to pay it. I'm not sure I need to do that, now that I know the probable cause: all I have to do is push the panic button again to stop the alarm.
  6. rigormortis
    1,340
    26
    san jose, ca
    as long as the doors are unlocked, the alarm is deactivated
    so i dont think its necessary to pay the dealer to have it done
  7. CatahoulaB
    CatahoulaB Redneck Member
    25
    Hamburg, Indiana
    Speaking of the key fob. I'm guessing this is a dunb question and it's probably covered in the manual and on the forums but....
    Why can't I leave the keys in the car? What would happen?
    Thanks.
  8. richard schumacher
    7,663
    1,038
    United States
    You can't lock the car, and thus can't confirm that the doors and hatch are actually shut (to prevent killing the 12V battery) as well as making it easy to steal the car.
  9. priusunum
    priusunum priusunum
    Virginia
    I reached that conclusion too, especially since I only had the problem when the doors were unlocked and the key fob was in my pocket. This should mean my problem is indeed due to accidentally pushing the red panic button on my key fob while it was in my pocket. I haven't had the problem again since I started this thread, but if I do, I now know what to do: just press the panic button and it will turn off the unwanted alarm!
  10. shahan
    shahan New Member
    Utah
    Hi....
    We just got a 2006 Prius a couple weeks ago and are still in the process of figuring things out.
    I just noticed today that the little 'car w/ the key in it' icon on my dash is flashing. I mean..all the time the car is turned off. Whether the door is open or not, or if doors are locked or not...it still flashes. When I turn the car on, it stops.
    I have read this part in the manual a dozen times or so and still can't figure how to turn it off. I don't know if it's been flashing the whole two weeks since we bought the car or if I've just done something recently that is causing it to flash. I'm really thinking that it isn't supposed to be doing this.
    Can someone please help me?
    Sharon in Ut.
  11. qbee42
    18,058
    3,074
    Northern Michigan
    You don't turn it off. You can pull out the battery and it will stop flashing, otherwise leave it alone. It's there to tell you that the immobilizer system has been enabled.
    Tom
  12. shahan
    shahan New Member
    Utah
    Re: flashing 'car' icon
    Ok....sounds strange that it should keep flashing indefinitly, but I'm happy to know it's ok.
    Thanks,
    Sharon in UT
  13. jrmason
    jrmason New Member
    30
    Somewhere above the equator
    You might try this. Roll down the window, Lock the car and make sure the alarm system arms. Your security light will go from solid to flashing. After arming reach in the window and pull the hood release. If the alarm goes off you can disarm the alarm simply by bypassing the hood switch which is usually up in the hood latch in the grill area. If your lucky you can reach the plug and just jump the two wires together and the alarm won't arm. Even if the hood is closed with the latch the alarm system thinks it's still open and won't arm the system. A couple of drawbacks to this. The system can't protect your car. And since the alarm is waiting for the hood to close your Body Control Module might not go into low power mode and draw more power from your battery than necessary. It would be worth a try.
    Jon
  14. qbee42
    18,058
    3,074
    Northern Michigan
    Regardless, the little light on the dash is supposed to flash when the car is off.
    Tom
  15. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    Sure.
    I'm not certain if the page number in the 2007 Owners Manual are the same as the 2006, but in my Owners Manual, on page 7 there is a list of indicators and their meanings. The indicator you describe is refered to as:
    "Hybrid vehicle immobilizer / Theft deterrent system indicator light"
    On page 21 there is an explanation of the "Hybrid vehicle immobilizer system" for smart key use:
    "DEACTIVATION USING THE SMART FUNCTION
    The hybrid vehicle immobilizer system is a theft prevention system. When you enter the vehicle carrying a smart key and press the "POWER" switch, the electronic code in the key is automatically checked to determine wether is corresponds to the registered ID code for the vehicle. If the ID code is verified, you can start the hybrid system."
    continued on page 22 with:
    "Carrying a smart key and pressing the "POWER" switch automatically cancels the system which enables the hybrid system to start. The indicator light will go off."
    On page 22 there is an explanation of the "Hybrid vehicle immobilizer system" for non-smart key use:
    "DEACTIVATION USING THE KEY
    The hybrid vehicle immobilizer system is a theft prevention system. When you insert the key in the key slot, the transponder chip in the key transmits an electronic code to the vehicle. The hybrid system will only start when the electronic code in the chip corresponds to the registered ID code for the vehicle."
    continued on page 23 with:
    "Inserting the registerd key in the key slot automattically cancels the system, which enables the hybrid system to start. The indicator will go off."
    Furthermore both page 22 and page 23 indicate:
    "The system is automattically set when the hybrid system is off and driver's door is opened. The indicator light will start flashing to show the system is set.
    If any of the following indicator conditions occurs, contact your Toyota dealer.
    • The indicator light stays on except when the theft deterrent system is setting or activating (See theft deterrent system on page 46.)
    • The indicator light does not start flashing when the hybrid system is off and driver's door is opened.
    • The indicator light flashes inconsistently.
    For your Toyota dealer to make you a new key with built in transponder chip, your dealer will need your key number and master key. However, there is a limit to the number of additional keys your Toyota dealer can make for you.
    In other words:
    If you turn the car off and open the drivers door, the light should start flashing. It should continue flashing no matter if the doors are locked, unlocked, opened, or closed. If you insert the key into the slot (or carry the smart key into the car and press the "POWER" button), the indicator should stop flashing. This sounds like exactly what you are describing, so it seems that it is working fine.
    There are further details on page 46.
    Try looking in the index of your Owners Manual under "Theft deterent system" and "Keys" if your pages don't match mine.
  16. shahan
    shahan New Member
    Utah
    Thanks very much for the explanation. It all makes sense now. :)
    Sharon in UT
  17. richard schumacher
    7,663
    1,038
    United States
    It flashes to tell would-be thieves "don't bother trying".
  18. Chthornton
    Chthornton New Member
    Santa Monica, CA
    I have taken my 2005 Prius in for service 4 times regarding the spontaneously sounding alarm. They have replaced the 12v battery and reduced the sensitivity of the alarm but problem still persists. In the owner's manual (pg 45) on the Theft Deterrent System it says that 'this function can be deactivated', however I've called 2 Dealers (West Los Angeles area) who say it's not possible. Any thoughts?
