Dead 2006 Prius
Discussion in 'Gen 2 Prius Main Forum' started by PopCorkOff, Apr 19, 2024.
  1. PopCorkOff
    PopCorkOff Junior Member
    24
    My friend's friend came out of the bank and his 2006 Prius was DEAD. His UCAN -II-B scanner brought up the following codes and he wonders what to do:
    02-Hybrid Control Fault 1
    05-ABS/VSC/TRAC Fault 4
    08-Transmission Control Fault 4
    Any suggestions would be appreciated.
  2. Tombukt2
    Tombukt2 Senior Member
    9,135
    1,586
    Durham NC
    You will need the real codes the numbers that go with those codes like PO420 that sort of thing.
  3. Leadfoot J. McCoalroller
    7,173
    6,722
    Pennsylvania
    2018 Prius c
    Those read like a count of each type of fault. I don't know that code reader, but I'd guess that you have to click into each of those three categories to see the list of error codes within them.
    Brian1954 likes this.
  4. mr_guy_mann
    mr_guy_mann Senior Member
    3,470
    1,514
    NJ-USA
    How dead is "dead"?
    If that scanner is actually getting codes from systems like hybrid control or ABS, then some of the car is actually powering up to "ignition on" mode.
    Does the dash (speedo) light up? How about the rest of the displays? Any warning lights?
    As mentioned, please post the actual code numbers from all the systems.
    Just wild guesses but you could have a capacitor in the Combination Meter (speedo) that can prevent the car from turning on. Or a failed inverter water pump that popped the AM2 fuse.
    Need more info.
