Dead as a doornail
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by JIM777, Feb 23, 2018.
  1. JIM777
    JIM777 Member
    162
    24
    Ar
    Was running fine stopped at the gas station filled with gas got back in to no lights at all as if 12 volt battery had been removed. Would not do nothing even with key in slot. Thought I try jumping it started right up drove it home figured 12 volt battery was shot not so even with the load still 12 and a half volt.
    2007 with 130,000 miles.
    Interesting thing when I stepped out of the car another Prius pulled in behind me and the older gentleman asked how I like my Prius I said I love them when it works he said best car you ever had :) now it's starting like a champ can anybody help so this don't happen again thanks have a great day. Jim
  2. JIM777
    JIM777 Member
    162
    24
    Ar
  3. JIM777
    JIM777 Member
    162
    24
    Ar
    Little PS2 the post when I open the spare tire compartment found water laying in there also found water laying at the 12 volt battery not to misdirect the problem but thought I'd add that if anybody has any ideas as to that issue would appreciate it as well thanks
  4. Mendel Leisk
    40,574
    Do you know how old the battery is?
  5. JIM777
    JIM777 Member
    162
    24
    Ar
  6. JIM777
    JIM777 Member
    162
    24
    Ar
    2007 /130000 miles
  7. Stevewoods
    Stevewoods Senior Member
    655
    1,069
    Seattle, WA
    I would venture 12v -- I know, I know, but if it is truly the original -- it's the 12v.
    pilotgrrl likes this.
  8. Prodigyplace
    12,403
    11,681
    Central Virginia
    You need to test the 12 volt battery after it has been sitting for a while, before turning the car on.
    Whenever the car is in READY it charges the 12 volt battery even if the engine is not running.
    Some people leave the hood ajar to they can test the 12 volt after sitting without opening the drivers door or starting the car.
    pilotgrrl and Stevewoods like this.
  9. JIM777
    JIM777 Member
    162
    24
    Ar
  10. JIM777
    JIM777 Member
    162
    24
    Ar
    Yeah it's not 12 volt battery that tests good and it's only 6 months old.
  11. Mendel Leisk
    40,574
    Tests good? Electronic load tester is best, will check both the voltage and the Cold Cranking Amps. Many battery retailers will have such a tester. Is that how it was tested? In a pinch, an at-rest, car-off reading of voltage will give you some clue.
    Stevewoods likes this.
  12. Stevewoods
    655
    1,069
    Seattle, WA
    As Mendel said and Prodigy said. If it were me, I would leave it sitting for at least eight hours, then test at the jump point under the hood (a bit easier to get to then messing with the actual battery).
  13. terramir
    terramir Member
    318
    50
    Los Angeles
    jump point under the hood you can't get a dam clamp attached to that dam thing the plastic is in the way #$%@ing jump point!!!! As for your problem if it's 6 months old it could be a loose clamp especially if the battery is not oem but bosch or others or if it way tightened to hard those are lead terminals after all.
    I used a cut up hose clamp (cut screw stuff off use as sort of a ring shim) around the lead post to clamp in tight on the positive side, which was slipping took me a while to figure that out because that was a brand new bosch install pepboys did just a few weeks b4 the trip(only reason they installed it was to save me the sales tax on the core charge hehe ;-)).
    While I was viewing the eclipse last year (in madras like almost 900 miles from home lol) I have not had 12V battery problems since. ;- )
    terramir
  14. JIM777
    JIM777 Member
    162
    24
    Ar
  15. JIM777
    JIM777 Member
    162
    24
    Ar
    Okay here it is checked all battery connections 12 volt is fine.
    Do these vehicles have any disconnect for the battery if the car rolls over.?
    The only thing I can think of is when I was filling the fuel it would hardly take it and kept cutting the pump off had to go on the slowest speed. Was the spout so full that it thought the car was upside down? And then was reset when I hook the jumper cables to it? Just a thought. Does anybody know how to fix this an the filling problem?
    Thanks for all the input so far. Jim
  16. terramir
    terramir Member
    318
    50
    Los Angeles
    oh no way to fix that gas problem if you pump it in slowly the 1st time it clicks you got like almost a gallon to go especially if you have a 14 1/2 yr old gas bladder in the tank. the gas gauge on the Prius is crap too needs at least 3 gal to register anything period. this car is the slowest fill of any of my cars and I had 2 fox body mustangs an f150 with dual tanks and a d200 75 dodge lol. that went faster at least if you want it full.
    terramir
  17. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    When the car rolls over? What...the car rolled over?
    Open hood. Take cover off fuse box. Flip up red plastic cover. Thats the 12 volt positive post. Measure there with voltmeter.
    With car off turn on the headlights on high beam with car off. What does the voltage read at that jump point?.
    And the jump point is very easy to hook jumper clamps too btw. It has a metal vertical tab thats bolted to the jump bolt.
    Its there to attach jump clamps. No plastic in the way.
    padroo likes this.
  18. JIM777
    JIM777 Member
    162
    24
    Ar
  19. padroo
    padroo Senior Member
    2,763
    2,251
    Sometimes your volt meter will lie to you, you need what is called a "loaded circuit test" like mentioned above. An unloaded test will read battery voltage, a loaded test will show what it is putting out under load.
  20. edthefox5
    10,096
    4,831
    Clearwater, Florida
    You must have a pos voltmeter. Who’s going to have an electronic load tester? I’ll settle for a voltmeter and a simple test first.
    My 2 year old yellow top tested 12.63 sitting. With car off and high beams on it tests 12.10.
    So that’s a .5 volt drop. If op reports a 2 volt or 3 volt drop or his sitting voltage is really low to begin with go no further.
    padroo likes this.
