Dead battery and key
Discussion in 'Gen 2 Prius Main Forum' started by Wrecit, Jan 14, 2025.
  1. Wrecit
    Wrecit Active Member
    169
    107
    Pittsburgh
    2001 Prius
    I
    Wife’s Prius been sitting for a while so figured I would go start it up for a bit. (Been 3 month in north east on old 12v)
    problem is 12v battery is dead and the key in the fob is not working (yea I sprayed the lock) I got a few ideas but she probably won’t like it so question is……
    any way to pop the hood from outside the car without breaking it
  2. PriusCamper
    PriusCamper Senior Member
    11,977
    4,869
    Pacific Northwest, USA
    You're in the Gen2 forum but have a Gen1 listed in your profile and I think you bought a Gen3 so I'm not so sure which vehicle belongs to your wife. But assuming its Gen2 here's what you need to know... You basically have the equivalent of locking your keys in the car and basic car entry gear on the window with bladder inflater to get an opening wide enough to get a rod in there to unlock a door is what you need to do. Or just keep pouring hot water on the lock and squeezing some graphite into the lock to get it open might work. Also make sure you're using the right key. Sometimes in a family with multiple Prius they can get mixed up.
  3. pasadena_commut
    pasadena_commut Senior Member
    2,215
    661
    Southern California
    Take the VIN to a dealer and they can make a new key. The one you have may be worn, damaged, or not for that car.
    Or variations on this:
    Gen 2 Hood Won’t Open - how to open | PriusChat
    I have not tried this, but if you have a borescope you might be able to snake it into a position where you can see where the cable attaches, and then using that view, snake in a coat hanger (probably from as far towards the driver's side of the grill as you can go) and pull on the release. All the methods like the one in the link above assume that all you can see is what is visible through the grill. There might be other options with a better view.
  4. Hayslayer
    Hayslayer Member
    181
    98
    Any chance you have AAA and forgot they offer lockout and dead battery services?
