dead battery charging?
Discussion in 'Gen 3 Prius Technical Discussion' started by camry25, Aug 12, 2012.
  1. camry25
    camry25 Junior Member
    46
    l.a.
    Someone's battery was dead at the aiport and they said jumpstart was different; it was not instant charge but 30 minute slow charge. Is this true? Can most tow trucks handle that?
    51,140
    somebody with a prius?
  3. PriusCamper
    PriusCamper Senior Member
    12,048
    4,892
    Pacific Northwest, USA
    What's different about a Prius that needs a jumpstart compared to a regular car is that if you accidentally reverse the terminal you can do $10K in damage to the car... And yes a 30 minute trickle charge to the battery works, but you can jumpstart the car normally as well. Just don't get how you connect to the terminals wrong!
  4. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    Your Prius has 3 main batteries
    1) The HV battery is unlikely to completely discharge, but if it did, you need to tow your car to a dealer. Even they may not have a charger, they may need to have it shipped from Regional.
    2) the 12 volt battery is small, so charge it from a non running car. Be very careful about the jumpers, wrong polarity can cause multiple thousands of damage to parts. My advice would be to replace the 12 volt if it is worn down to needing a charge.
    3) the Fob battery is under $5 and is a common watch battery.
    PriusCamper likes this.
  5. NiHaoMike
    NiHaoMike Member
    98
    16
    Use 8 D cells in series to jump start it. They won't supply enough current to do damage (at least for alkaline D cells) even if connected backwards.
  6. macman408
    macman408 Electron Guidance Counselor
    1,179
    367
    If you do that with a discharged 12V battery still connected, I question whether the D cells could supply enough current to both be charging the 12V battery and raise the voltage enough to power on the car. Undoubtedly, it depends on just how far discharged the battery is.
    To the OP; you can jump start a Prius from anything. Hook up the cables, press the power button. No need to rev the other car's engine, or even let it charge first. Once the Ready light is on, disconnect the cables; the HV battery is charging the 12V battery even before the engine comes on. The engine is started from the HV battery, not the 12V battery; the 12V battery just powers on all the computers. (However, if the 12V battery is dead, the computers can't power on, and thus the HV battery can't be enabled and the engine can't be started.)
    The reverse is not true; because the Prius has a small 12V battery, and because the 12V system is being supplied through a DC/DC converter from the HV battery, it can damage the Prius to jump start another car; the converter can't safely supply enough power to crank the engine on the other car.
    And as with any car, damage can occur while jumping or being jumped. On the Prius, it can be especially expensive, since electronics are deeply integrated into the drive system, so many owners are overly cautious, and may prefer to use a battery charger, many of which can detect reversed polarity, overcurrent, or other fault conditions.
