Dead Battery need Help
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by vikx, Jan 4, 2010.
  1. vikx
    vikx New Member
    17
    WA
    Hello all, searched and have found lots of good info, but still need help. Had the oil changed last week on my 05, 19 K miles. Drove home with no problems and a trip to the store mid week. Went out tonight to load my tools and doors wouldn't open.
    Battery is totally DEAD. Charger didn't work (assuming this is because the battery is toast), registered .4 volts on the tester at the jump points.
    I haven't taken the back of the car apart to get to the "real" battery terminals, but will crawl in there tomorrow and try to open the hatch, etc.
    This is the 2nd 12 volt battery since buying the car new. First was replaced under warranty, this one is approx. 2.5 years old. Is this a common scenario? I mean, to have the battery so dead it won't register any voltage? (0.4v)
    Is there an inline fuse that might cause this?
    Thank you in advance for any responses or advice. VK
  2. vikx
    vikx New Member
    17
    WA
    Sorry, I checked the fuse block and the big clear fuse box with the copper lines in it-they "looked" intact. VK
  3. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    2005 with only 19K miles? wow. I thought my 2007 bought last April with 13K miles was low mileage. I've put 10K on it since!
    The low mileage may be playing a part - does it sit parked a lot or do you just have incredibly short trips?
    Who did the oil change and did it take long? I can imagine a scenario where they left it in ACC mode the whole time instead of properly turning it off, which may have killed an already weak battery. When I had my car aligned I got it back with the traction battery almost completely drained, amazing what some shops don't know about the car.
    - D
  4. vikx
    vikx New Member
    17
    WA
    Yes, I do drive it almost every day, obviously short trips. (15 miles or so) It gets better mileage on the freeway than in town.
    Toyota dealership did the oil change, about an hour. I was a bit suspicious since the car had not glitched since 12v battery was replaced in 07; however it's unlikely they "did" anything to cause the above.
    Totally frustrated. I can imagine being stranded on somebody's farm late on and not being able to jump this car. Have done the research to change out the battery but still am surprised it is so totally DEAD. Thanks, VK
  5. Patrick Wong
    18,210
    6,514
    There is a 120A MAIN fuse located in the little fuse block attached to the positive battery terminal. It would be highly unusual for even a dead 12V battery to measure 0.4V. Are you sure that your meter is working properly? Try measuring directly across the battery terminals.
    That is the fusible link box within the main relay/fuse box near the inverter which contains the 100A DC/DC fusible link among others. However, you also need to check the MAIN fuse located on top of the 12V battery as mentioned above.
    Since you are driving the car <4K miles per year, this lack of use is the most likely reason why the 12V battery is failing.
    If you can park in an area where an 120VAC outlet is available, then you can hook up a battery minder full-time or use a battery charger periodically. If not, then buying batteries from time to time is a cost to be borne, given your light vehicle usage.
    2 people like this.
  6. vikx
    vikx New Member
    17
    WA
    Thank you Patrick Wong. I will check the battery fuse this morning after I access it. It was late afternoon when this was discovered so it got dark before I could do much work.
    I was a bit surprised myself about the .4 volts-cheap LED meter but would go to zero when not used. Hmmm. The charger would not put voltage to the jump points either. (has some sort of battery sensor circuit) What typically would cause the main fuse to blow?
    I will post back on what I find. VK
    PS: Yes, we use battery tenders on everything, but not the Prius since it is driven quite often....I don't mind replacing the battery but having to be a contortionist to get the hatch open is annoying.
  7. Patrick Wong
    18,210
    6,514
    If you have a 9V battery lying around the house, use your meter to measure voltage on that battery, as a test of the meter.
    Typically the only reason that the 120A MAIN fuse would blow is that there exists a severe 12V wiring problem that caused a major short. Or the Prius was used to jumpstart another car; or vice-versa, and the battery polarity was reversed.
    Most modern battery chargers will refuse to output current until the charger detects that battery polarity is correct, and that battery voltage is high enough so that the charger will not be putting current into a shorted battery. This is a safety feature of the charger.
    2 people like this.
  8. vikx
    vikx New Member
    17
    WA
    Pretty confident it's not a shorted 12 volt system; never used it to jump-must be in the battery; dead batteries can cause all sorts of weird things. Thanks for the tips, back tonight. VK
  9. rjsailnsd
    rjsailnsd New Member
    Escondido, CA
    I have a 2005 that the just had the 12 volt battery die. It was the original battery and it lasted 4 years to the month. I live in So CA in mild temperatures and the battery died on a ski trip to Mammoth at 7000 ft and temps in the high 20s to mid 30s. Even with that the battery would charge to 12.80 volts and if left connected overnight , the next morning voltage was about 10.4 volts. I did peel the top label off the battery to access the cells. Only 2 of the 6 were still flooded with electrolyte. I ended up buying the Toyota OEM battery when I got back to San Diego. The car has 71000 miles on it and I will not have it 2 more years, so I didn't bother with the Optima Yellow top conversion.
    I couldn't get the right battery in Mammoth , so I removed the battery out of its spot in the rear fender and used jumper cables to bring it forward in the cabin so I could connect a volt meter to see what voltage the old battery was at when driving (it was 13.85V). This way I knew the charging circuit was working. When I would stop the car and turn t off the old battery would be at 12.80 volts and then you could watch that voltage just fade away within minutes.
    2 people like this.
  10. rjsailnsd
    Escondido, CA
    Check to make sure your test leads on the meter are good by checking their resistance.
    Also , make sure the meter is in DC volts function and on the right voltage range to measure 12 volts DC.
    2 people like this.
  11. jdenenberg
    jdenenberg EE Professor
    3,957
    1,955
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Your (and my 2004) Prius uses a "constant voltage" charging system that provides a very slow (and easy on the battery) charge and short trips are not sufficient to maintain the small 12v battery. Use a Battery Minder (or Tender).
    (clip)
    I carry a small jumper battery (it also has a light and an air pump) with me when traveling. It is inexpensive insurance (I've never needed it for my Prius, but it has jumped other people's cars (as well as my emergency power generator) several times. Just remember to keep it charged up so that it is ready for the next use.
    Next time you need to replace this battery get an Optima Yellow Top (and adapter kit) from:
    http://www.elearnaid.com/12vo1topraub.html
    It handles deep discharges better and has a bit more capacity. Hopefully it will hold up longer in your use.
    JeffD
    ps. Patrick knows his stuff. Listen to him.
    2 people like this.
  12. vikx
    vikx New Member
    17
    WA
    Update: Crawled into the back and got to the battery. After removing the paraphernalia, found that the battery was indeed bad. Tester said 3.84 volts with it disconnected. Hooked up a portable battery and all the dash lights blinked, car started honking and doors unlocked with the fob...
    Purchased the factory battery from Toyota: $224 including tax; not because it is the best but because I could get the car on the road now and for another two years, when I'll pry be driving a new plug in Prius.
    The tester was/is good and I will continue this saga if problems are encountered with the re-install. Thank you all so much. VK
    PS: The car would not accept a jump from the portable that I carry; nor would it accept a charge from a good quality charger. When this happened in 07, it was easy to jump, then drive to dealership where the battery was replaced under warranty. This was what had me so frustrated: no way to unlock/open the doors, especially the hatch, so I could get access to the battery.
  13. don_chuwish
    823
    190
    Southern Oregon
    Glad to hear you're back on the road anyway. I agree with jdenenberg that a battery minder of some sort would be a good thing to do once in a while. (Monthly? Weekly? do not know, you'd have to check it periodically to see what it needs.)
    One of my Christmas presents was a Battery Manager from Griot's. Pretty much identical to VDC's BatteryMinder I think. Also included in the gift was an optional quick disconnect lead which I've now permanently attached to the battery (+) terminal and ground, then left sticking up into the cargo area (see photo). I think this will be both easier and better than charging from the fuse box jump point under the hood. Maybe this would help you too? Just a suggestion!
    - D
    2 people like this.
  14. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    That's because the 12v battery was beyond bad. Sometimes a seriously failed battery will act like a short circuit, draining away any attempt at a jump start.
    Tom
  15. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    $224 ? :eek:
    I hope it's just a typo for $124. Still not cheap though. :(
  16. vikx
    vikx New Member
    17
    WA
    Thanks Dave, that's exactly what I had in mind! Was trying to figure out a way to mount an external port-the bumper maybe? I have a lot of maintenance chargers but will use the Minder on the Prius.
    Not a single glitch or warning of the battery going bad. Just DEAD.
    $224 is NOT a typo-unfortunately. Other batteries in town were close to that price so I bit the bullet. The car will be on the road today... VK
  17. richard schumacher
    7,682
    1,062
    United States
    $224 may be a tad pricey, but I don't recall seeing anyone paying anything close to $124 for a new Toyota battery installed. They're not cheap. Neither is the Optima.
