Dead battery?
Discussion in 'Newbie Forum' started by Sunil Chatterjee, Mar 3, 2014.
  1. Sunil Chatterjee
    Sunil Chatterjee New Member
    Hi:
    I just bought a 2007 Prius. This is the second time it has gone 'dead'. AAA jumped it the first time 10 days ago. It is dead again today. What do I do?
  2. JC91006
    16,487
    8,401
    If a battery is not holding a charge, you would need to replace it. Do you have any way of charging the battery and testing it? If you don't have a way to charge the battery to test, it would be safe to just replace it. Odds are, it's already dying from the 2 incidents of it needing to be jump started.
  3. fuzzy1
    10,175
    Odds are, if the 12V battery is original, it was probably already dying from age before those two incidents.
    Sunil Chatterjee likes this.
  4. Sunil Chatterjee
    Hi JC91006:
    I think you are right. Where is the battery located?
    Is it a conventional battery?
    Is it easy to remove it and take it to have tested?
    Would a Toyota dealer have to be involved or could some one like a SEARS Automotive provide the replacement battery?
    Thanks,
    Sunil
  5. JC91006
    16,487
    8,401
    The battery is located in the rear passenger side of the the trunk. You can call some local dealers in the area to see how much they would charge for the battery. The prices will vary a bit. It can cost anywhere from $250 - $350 dollars to replace this battery at the dealer. Parts alone will be close to $200.
    Also I would be very careful in having AAA jump start this car, if they do it wrong and reverse the polarity of the battery, they can possibly do $4000+ damage to the car.
  6. JimboPalmer
    12,470
    6,867
    Greenwood MS USA
  7. JC91006
    16,487
    8,401
    If you provide your location, there may be some independent shops that members can recommend for you.
  8. JimboPalmer
    12,470
    6,867
    Greenwood MS USA
    Here is the Exide Edge from Sears Sears.com
  9. bisco
    49,531
    don't waste your time, go right to sears. if they say replace it, replace it. make sure you're not leaving a map light on and the hatch closes properly snf lites go out.
  10. Sunil Chatterjee
  11. Sunil Chatterjee
    Good advice - thank you!
