Dead battery
Discussion in 'Gen 2 Prius Main Forum' started by Dummy, Jun 5, 2022.
  1. Dummy
    Dummy Member
    106
    22
    Colorado
    I left if parked for a month and had to jump it. The hybrid battery shoes two bars and took 50 miles to charge to half. After 100 miles it hasn’t made it any higher. Should I be worried?
    49,537
    at 17 years? probably, but it might just be normal.
    press the brake hard and floor it to fully charge
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    The fact that it still is the original battery tells me that car has has been driven alot probably 250K+ miles on it.
    Which is great for the hybrid battery. But then letting it sit for a month is really hard on it. 150 miles should have charged it up unless ac is on full blast and going up and down hills. You should be mentally prepared for this anyway right?
    No matter what its pretty corroded in there and letting it sit will excite corrosion. And the 12 volt battery is probably now fubar so be aware of that. Buy a jump pack.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,246
    5,945
    Columbia, SC
    Left a 2005 parked for a month and had to jump it.....pretty normal if it's an average age 12v battery. Even a brand new one will only last about 6 weeks before it gets extremely weak, due to the normal small loads.
    It showed two bars after sitting for a month. Pretty normal for an original HV battery. Maybe even pretty good, since it's not showing the RTOD. A bit of self discharge, but fairly even. No "one" module doing a crazy self discharge and coding the battery. Not all bad!
    Charged to midway after about 50 miles....perfect. Mid way is the normal operating band. The car tries to keep it between ~42% and ~62% during normal operation.
    Still midway after 100 miles....see above statement.
    Dummy likes this.
  5. Dummy
    Dummy Member
    106
    22
    Colorado
    I like your response best
  6. Dummy
    Dummy Member
    106
    22
    Colorado
    You’re right I should buy a booster pack. Can you clean corrosion from the hybrid battery?
  7. Another
    Another Senior Member
    1,802
    511
    Naples, Florida
    Get Dr Prius app, preferably the paid version, and look at the results.
