Dealer claims rear shocks leaking oil - pictures - real or fake news?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Blajoie, Aug 4, 2018.
  1. Blajoie
    Blajoie Junior Member
    San Diego, California
    2012 prius three, 91xxx miles.
    Just had an oil change done.
    Dealer says the left rear shock is leaking oil and needs to be replaced. Both are recommended to be replaced. $352 per side, $704 + tax total.
    Can anyone confirm if these pictures justify a replacement? The left defiantly seems 'wetter', but no huge oil streaks, and I've yet to noticed any drops in the garage etc.
    Car still drives same as before, no vibration / bounce. Should I consider a replacement - planning to keep the car until it dies.
    Left rear
    Right rear
    Thanks!
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,474
    Bay Area, California
    2019 Prius Prime
    Are you noticing any ride issues:whistle:?
    While they may be on their way out, I would shop around as the rear shocks can be done anywhere ;).
    I just did ours and got a set of KYBs for the rear for under $80:).
    About an two hours to install as you have to disassemble the back of the car to access the top nut:(.
    But an easy diy job if you have tools (y).
    #2 Raytheeagle, Aug 4, 2018
    Blajoie, m.wynn and frodoz737 like this.
  3. Spenny
    Spenny Member
    82
    25
    Unless the component will affect anything else when it fails, I don’t see the point in preemptively replacing it. That should be easy enough to do yourself with a few hours I would think.
    Tande, m.wynn and Raytheeagle like this.
  4. frodoz737
    frodoz737 Top Wrench
    4,297
    2,347
    33
    Replace, but not at the Dealership. If you can't do it yourself, most shops will do it for way less.
    Blajoie, Tande, m.wynn and 1 other person like this.
  5. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,551
    Bay Area
    I would check suspension warranty before replacing it. I remember one time there was a situation the customer saying the shocks were seeping like yours and the dealership replaced it under warranty.
    Raytheeagle likes this.
  6. frodoz737
    4,297
    2,347
    33
    2012 prius three, 91xxx miles...
    It would be nice, but shocks are a wear item.
    #6 frodoz737, Aug 4, 2018
  7. tankyuong
    tankyuong Senior Member
    1,555
    659
    Central MO
    looks fine to me
    Mendel Leisk and Tande like this.
  8. ASRDogman
    ASRDogman Senior Member
    5,837
    3,137
    I can't tell from the photo that it's leaking.
    You replace something that is worn, BEFORE it brakes, so it doesn't cause damage to something else.
    Think what could happen if a rear shock broke, you could have a wreck, it could jam into the ground, wheel,
    damage the mounting.....
    You replace your oil(SHOULD) before it brakes down completely and it's like no oil at all. Then you have metal on metal
    and it won't last long.
    Blajoie likes this.
  9. Spenny
    Spenny Member
    82
    25
    BTW, every time you use the phrase “fake news”, a baby seal dies. 3BC51194-5FE3-484C-8777-702A11315F19-2437-000001871B17B554.jpg
    Blajoie, TheChip and Mendel Leisk like this.
  10. ASRDogman
    5,837
    3,137
    How much is the price of rice in china?
    Freddog12345 likes this.
  11. Dxta
    Dxta Senior Member
    1,932
    766
    Lagos
    The left shock is definitely leaking oil, and that's a sign its already ojnits way South! If you don't experience any suspension related noises when you drive, then drive it till it dies(according to you). If you got the cash, replace both. The right one also has some kind of oil stains, but not at the level of the left.
    Buy KYB, of any other one you choose. Since they are the rears, not too difficult like the front with the coil springs.
    Blajoie likes this.
  12. Blajoie
    Thanks all. No ride issues thus far.
    Pretty sure I am far beyond any sort of warranty. Def over my years and mileage allotment.
    Will look into doing this myself - have most of the tools and a quick YouTube video makes it look not all too bad.
    Any tips on the best place to buy new shocks? Don’t mind paying a bit more for quality. KYB? Something else?
    Tire rack seems to have everything. $134 for the pair seems reasonable? How about new shock mounts?
    #12 Blajoie, Aug 5, 2018
  13. ASRDogman
    5,837
    3,137
    I think you'll find a ride difference after you replace them.
  14. Raytheeagle
    11,251
    15,474
    2019 Prius Prime
    When I bought the KYB’s they came with new mounting hardware for the top as they are single time use ;).
    All I needed to reuse were the boot and lower bolt and nut:).
    $134 seems reasonable;).
    Good luck and keep us posted (y).
    Blajoie and Tande like this.
  15. Leadfoot J. McCoalroller
    6,690
    6,379
    Pennsylvania
    2018 Prius c
    They don't look that bad yet. Replace them when the weather is nice and you have some easy time to work on it. Not urgent at all.
    Look at your old strut mounts. Chances are they're fine. You don't usually see them rip or rot until much older.
    Blajoie likes this.
  16. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    I see zero problems with these struts.
    The stealership loves to do ‘preventative maintenance’ for no reason.
    Until you see and/or feel a problem with ride, leave it be
  17. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,780
    2017 Prius c
    Me too.
    Typical repair scam.......at a WAY inflated price.
    Maybe you should look for a different dealer for your service.
  18. Lucifer
    Lucifer Senior Member
    1,014
    485
    Nh
    Those are shocks, and simple to replace, at that age, check the KYB’s prices and grab a set, the fronts are probably struts, (inside a spring) so a dealer would do them and then an alignment, safer, better ride, etc.
    Blajoie likes this.
  19. William Redoubt
    William Redoubt Senior Member
    1,215
    1,164
    Coronado Island, California
    Yeah, just nuts and bolts and a set of interior tools ($10 at Harbor Fright). Here's a link to the directions, with pics: Rear Shock Replacement - Tips and Notes | PriusChat
    Blajoie and Raytheeagle like this.
  20. William Redoubt
    1,215
    1,164
    I too, see no evidence of leakage, with one exception. Watch for greenbacks leaking out of your wallet. Ask that b@stard to put the car on a lift and show you the leakage, notifying them in advance of the photos you have in hand. They will tell you that customers aren't allowed in the work areas due to "liability" reasons. The largest liability being your ability to show them to be liars. Find another service provider and Yelp those dudes with the truth.
