Dealer fighting back on drain and fill transaxle
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by guycalleddave, Dec 15, 2015.
  1. guycalleddave
    guycalleddave Junior Member
    34
    grand rapids, mi
    I've read the results, and I tend to agree with real world tests than anything else.
    The dealer says they are trying to save me money and that the fluid is fine for 100k, we've all heard it before.
    I talk to the service manager who said that the drain and fill only removes what's in the pan and the 13 liters or something is really in the car.
    I haven't found a reference to this exact line yet, so I said thank you and I came here.
    Is it true that the other fluid, in what ever quantity is in there, intermixes with the 3.8 liters/quarts drained in the drain and fill.
    Also is it true that a flush should be performed at 100K?
    new to me '13 Prius Persona, 54,400K miles.
    52,763
    no, both are incorrect. you get most of the oil, and toyota usa calls it lifetime. find a dealer that doesn't want to 'save you money', should be easy, under a hundred bucks.
  3. guycalleddave
    34
    grand rapids, mi
    they said they'd do it for 120 bucks which is a little on the high end, but they have the car now and could have it done for when I pick it up in 2 days!
  4. Mendel Leisk
    42,251
    The Prius transaxle drains like a manual transmission, 90% plus of the fluid comes out when you pull the drain plug. I did a (DIY) drain at the one year mark (around 15,000 km), the three year mark (around 40,000 km) and will likely do one around the 6 year mark, around 11 months from now. It takes me a couple of hours with all the farting around, but for a dealership with a lift, 1/2 hour should do it.
    There is NO service interval given by Toyota, so if he gives you any interval, he's just making it up as he goes. There is NO need for a flush, unless someone has put the wrong fluid in there. There are something like 3.9 liters total in there, about 3.5 will drain, and that's what you put back in. All you do is pour it in 'till it starts coming back out (with the car levelled). Very simple.
    For DIY, the simplest way to get the fluid in is a funnel with hose extension. You should also have decent wrenches, a torque wrench, and a socket with a 10mm allen key (both drain and fill bolts have a 10 mm hex recess).
    Prices, in Canadian dollars, from my latest change invoice:
    (4) liters Toyota ATF-WS fluid: $9.32 (per)
    (2) drain/fill bolt washers: $1.99 (per)
    So in total around $40 plus tax for the supplies.
    #4 Mendel Leisk, Dec 15, 2015
    ftl likes this.
  5. mrstop
    mrstop PWR Mode
    740
    329
    109
    Cincinnati, OH
    I think it is funny that they push back on changing the transaxle fluid, yet push injector cleaning to their customers!
    I think the service manager is a bit confused about how your transmission is constructed. He would be correct if our cars had a torque converter. If it had the torque converter, a standard DIY procedure is to do a drain/refill multiple times. I do this on my Honda. Each subsequent drain/refill removes and dilutes the old stuff to a negligible amount.
    As Mendel states the Prius is more like a manual in that it does not have a torque converter and only requires draining and replacing the fluid. It is just about as simple as changing the motor oil.
  6. guycalleddave
    34
    grand rapids, mi
    So where are they getting that there is 13 quarts of fluid in the system? just trying to learn about the vehicle's composition.
  7. Tony D
    Tony D Active Member
    469
    132
    Dublin, Ireland
    alot don't know how the cvt works so try to avoid going near it
    Its a 10 min job - open plug, drain oil. replace oil, close plug
    re the 13 quarts, that's BS. There isn;t anything in the Prius that takes that volume , except the petrol tank
  8. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    So let me see if I got this. The service department doesn't want to take your money? Wow! Or maybe it didn't get to that, he was just trying to "go by the book". If you asked them to change it and they refused, then I'd be really surprised.
    He was "making it up as he went along". RTFM. 3.9 L as I recall.
  9. guycalleddave
    34
    grand rapids, mi
    she said that the drain and fill only replaces what's in the pan but that's only 1/3 of the transaxel fluid in the car, and that basically you're just adding new fluid to the other 2/3 of the old fluid?
  10. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    sure they want his money; $120.-..... ;-)
  11. Tony D
    469
    132
    Dublin, Ireland
    She doesn't know what she's talking about which is fine if she's not doing the work. I'd be more concerned if the tech doing the job told you that. If it was me i'd take it to an Indy mechanic and get it replaced by him using Toyota WS fluid, $100 or less
  12. sillylilwabbit
    sillylilwabbit Active Member
    405
    118
    Los Angeles
    2014 Prius Plug-in
    When you said "she", that pretty much explains everything....
    iPhone ?
  13. guycalleddave
    34
    grand rapids, mi
    let's leave the sexism at the door...it's not like this is a 'vette forum.
    Doug McC and PosauneGuy like this.
  14. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Similar experience here. They try to sell throttle body cleaning, injector cleaning, etc., but for some reason, they don't want to do the transaxle drain and fill.
  15. RHFACTOR
    RHFACTOR Junior Member
    Service MGR. Is mistaken. A little less than 4 qts. Total. You can get WS atf fluid at walmart and do it yourself for less than twenty dollars. Good luck!!!
  16. RRxing
    RRxing Senior Member
    2,562
    1,839
    NEPA
    NOTE: If DIY, remember to make sure you can remove the fill plug first before removing the drain plug, else you'll be up the proverbial creek. ;)
    sfv41901 and fotomoto like this.
  17. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Local dealer wanted 385$ for a trans-axle rebuild, wouldn't just change fluid, your should be avoided also.
  18. qdllc
    qdllc Senior Member
    1,377
    400
    Just make sure they flip the car over and give it a good shake to get the last few drops out. :ROFLMAO:
    I get being anal about getting it ALL out...especially when it's a rarely-serviced fluid. I make brake fluid changes easier (on my other vehicles) by siphoning off the old fluid from the reservoir at the master cylinder then filling with fresh fluid before I start. No point intermixing old with new at the source. This way, what's being pumped through the brake lines is 100% fresh fluid within the first couple of brake pedal pumps.
  19. bisco
    52,763
    $120. isn't awful. your done, and can put it behind you for another 30k. all the best.(y)
  20. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Lets be clear here, the Prius HSD is not like any other 'transmission'; it is a single speed manual with no clutch you can operate. There are very few moving parts, most of the 'transmission' is software that makes it appear to be a CVT.
    It is not likely that any non Toyota class would cover it, and Toyota has no set service interval, so a Toyota class might not cover it.
    Here is a good explanation, which does not cover servicing it, either. (Gen 1 and 2 are simpler than Gen 3, we do not know about Gen 4)
    #20 JimboPalmer, Dec 16, 2015
