Dealer Recommended Gen 3 Services?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by worldaven, Sep 29, 2023.
  1. worldaven
    worldaven Member
    113
    16
    Went to the dealer today to get the oil change on my 2010 Prius with 146000 miles. Had what I thought were rough transmission issues. Had it checked out for $109. They couldn't find anything directly, but recommended the following services:
    • Coolant System Fluid Exchange Service: $250
    • Transmission Fluid Exchange Service: $400
    • Throttle Body Cleaning: $150
    Just had the Throttle Body cleaned back in 2020, so not sure what they're talking about...
    The rest might be warranted, but it sure seems high...?
    Thoughts?
  2. PriusCamper
    PriusCamper Senior Member
    12,064
    4,896
    Pacific Northwest, USA
    Those prices are outrageous and none of them will do a single thing to make your symptoms better. A Toyota Stealership is where you go to get repairs under warranty that you don't have to pay for. After the warranty expires a Toyota Stealership is where you go to get ripped off for more money than all the other local mechanics. A 14 year old car needs a friend or family member or local mechanic focused on keeping the car on the road for lowest price possible.
    If you let us know which city / region you live in we might be able to recommend someone who is honest and conscientious.
    worldaven likes this.
    51,154
    Those are fine things to do, and the throttle body may help, but I wouldn’t spend the money until you eliminate a blown head gasket
  4. PriusCamper
    12,064
    4,896
    Yep... That's the Stealership plan... First overcharge for all the things that might barely help and make as much money as possible up front, then when they return to say transmission is still running rough tell them about the failed head gasket and Jack them up for another $5K without telling them about how Gen3 Piston rings go bad early so they can jack them up for another $5K in the future.
    Best solution is to buy a used Gen4 engine that doesn't have any of these problems and have the mobile Oklahoma guy do the engine swap in your driveway in a day for $1500.
  5. worldaven
    worldaven Member
    113
    16
    Louisville, KY. I've had work done at a couple of local mechanics. One is more expensive than the other, but on the less expensive one there is usually a two-three week wait to get an appointment. If you have any other recommendations, I'm always open to good reputable, fair-priced mechanics.
  6. worldaven
    worldaven Member
    113
    16
    This is good info...so my follow up questions are 1) where can I find a Gen4 engine (other than the local pull-a-part, junk yard) and 2) who is this "mobile OK guy" and where can I get a hold of him...?
  7. worldaven
    worldaven Member
    113
    16
  8. ASRDogman
    ASRDogman Senior Member
    7,241
    3,780
    This would be better, I think. And would be a quicker and easier change...
    https://hybridpit.com/1-8l-hybrid-engine-2zr-fxe-motor-bronze.html
  9. rjparker
    rjparker Tu Humilde Sirviente
    9,596
    5,893
    Texas Hill Country
    This will be unusual for me, but how do we know the op has a bad engine much less a bad head gasket?
    Granted “rough transmission” as a symptom is unusual, but that is often misreported when it’s really misfire based.
    The op seemingly has not said this roughness is at coldstarts or perhaps anytime the engine kicks on or just about anything that would lead us to believe it’s a ruined engine.
    #9 rjparker, Sep 30, 2023
  10. Mendel Leisk
    40,583
    Have you had it done before, and if so when? And which coolant, engine or inverter? (per Toyota USA: engine coolant is 10 years or 100k miles, 5 years or 50k miles thereafter, and inverter coolant is 15 years or 150k miles, 5 years or 50k miles thereafter)
    That may be a new record. I wouldn't pay over $100 USD, it's a simple drain and fill.
    DIY if possible. If interested I can post info.
    @rjparker may have it. Has Exhaust Gas Recirculation components and intake manifold ever been cleaned. You're getting close to head gasket failure time, and all Toyota and the dealerships are providing is runaround.
    Once the head gasket starts leaking coolant into the cylinders (typically starting with cylinder one, at passenger end of the engine), what usually happens is coolant collects in a cylinder overnight, and you'll get rough start in the morning, due uncompressible coolant. Eventually the springs in the damper between engine and transaxle fail.
    #10 Mendel Leisk, Sep 30, 2023
  11. PriusCamper
    12,064
    4,896
    Known as @HelloMcFly on PriusChat
    Real name is Drew Griffin: 405-696-9828
    I'm sure he'll know more than all of us about how to start your search for a Gen4 engine to be delivered and waiting for him when he shows up. The good news is you can go years with this head gasket symptom before you can't drive the car without damaging the transmission dampener. So you got time...
  12. PriusCamper
    12,064
    4,896
    duplicate (server is slow)
  13. worldaven
    worldaven Member
    113
    16
    UPDATE: I called a local independent dealer and they just quoted me $425 for all three jobs! Stealership quoted me $800. Wth?! I guess that's to be expected. I'm going to pass on the Throttle Body Cleaning because I just had that done at 120K. Now I'm still debating on the other fluid replacements...
    Should I still get the engine coolant and transmission fluid changed?
    I'm confused about the transmission flush. I'm seeing and hearing two different schools of thought. Change it and Don't Change it. The "don't change it team" claims that it's a lifetime fluid and shouldn't be changed, and the "Change it" team says to change it just to be safe and prevent future issues down the line... I have had some on-again, off-again shifting issues, especially in Eco mode. The dealership mechanic couldn't replicate the issue when he test drove it. I've had a couple of rough idles, but that was during the cold winter months, and have not experienced anything since. I had no check engine light, but I am concerned about the head gasket blowing at some point. Car currently has 146K miles on her.
  14. Mendel Leisk
    40,583
    You went in, ostensibly for an oil change, and asked them to check out "rough transmission".
    They got nowhere fast with the diagnostic, charged $109. Then, the dealership service advisor, likely working on commision, recommends everything-under-the-sun, mostly at preposterous prices, some of it well ahead of Toyota schedule, some of it not on the Toyota schedule, some worthwhile, some a total cash grab.
    Don't get stampeded, getting an independent to do all that stuff, just cus that service writer needed to make a car payment.
    Maybe get back to that rough transmission. With 146K miles, presumably EGR and intake never cleaned, you could have head gasket starting to fail.
    Are you in the US?
    If so, which State?
    Have the spark plugs been changed?
    Any odd shaking during cold starts?
    Engine coolant level stable?
  15. worldaven
    worldaven Member
    113
    16
    Yes. KY
    Yes. Spark plugs were replaced in 2020 at 110K
    A few months ago, a couple of times had a rough idle on cold starts, but that was also during cold winter days, if memory serves.
    Based on dealership's "50pt inspection" during the recent oil change all fluid levels were "OK"
    Yes, EGR and intake have never been cleaned. Could any independent mechanic get that done? How much would that cost?
    That would really suck. I just replaced all the brakes and need this to last at least another 30K. As much as I'd love to get a new car, I can't afford one at all right now.
  16. Mendel Leisk
    40,583
    There’s two shops in the States I’ve heard of, that’ll do this: Tampa Hybrids (Florida obviously) and Hybrid Pit Stop (LA). I know, a terrifically short list. Hopefully there’s more. Both places charge roughly $600 USD if I’m not mistaken.
    If you can manage an oil change you can DIY the EGR cleaning. A garage helps, especially in winter. It’ll take about a day in total. You can split it up, say do intake manifold in one session, and the rest say another weekend.
    There’s also things you can do in advance, when you’re fresh, say take off the lower bracket nut on the EGR cooler, and maybe the stud there as well. And just leave them off. Having that nut AND stud affords several adavantages: it’s then not necessary to remove the two rear studs on the cooler, and those rear studs will help to retail the rear gasket during cooler removal. Also, that lower bracket nut/stud is a BEAR to get at, the last thing you want to deal with halfway through the process.
    (More info in top 2 links in my signature. On a phone turn it landscape to see signature.)
    Just judging from reports here, 3rd gens are blowing head gaskets very regularly, somewhere between 150k and 200k miles.
    Why they’re blowing has become very contentious. My money’s on EGR clogging as the prime cause. I would recommend EGR cleaning every 50k, if you want to keep it operating as intended, like it did when new.
    Still, if your head gasket is starting to fail, and typically that means coolant leaking into the cylinders, EGR cleaning will not reverse that failure; the head gasket should be first priority.
    A leak-down test or boroscope inspection are the go to’s for checking head gasket condition. The latter easier for DIY.
    #16 Mendel Leisk, Oct 2, 2023
