Dealer refused to fix my car
Discussion in 'Newbie Forum' started by Sammorah, Sep 30, 2021.
  1. Sammorah
    Sammorah New Member
    Saudi
    2017 Prius Alpha
    Hello everybody,
    So I have this issue with my car which the servo motor actuator seems to be failed. I took my car to fix it they said it is out of warranty. Now I guess I am going to take it to indie shop or a/c shop to fix it.
    Can I have a Pdf for installing instructions and replace this item? Please
    Thank you
  2. Mendel Leisk
    38,729
    Did they refuse to do the repair, or just do it for free?
    Can you go into more detail; what is this servo motor actuator for, something in the air conditioning?
    kenoarto likes this.
  3. Elio Kim
    Elio Kim New Member
    Huntington Park
    2017 Prius PHV
    Two Eco
    You should look for an extended warranty, those are the best.
  4. JohnnyPR
    JohnnyPR Junior Member
    85
    23
    Hinesville, GA
    Definitely try if you can get the extended warranty.
  5. bisco
    49,500
    when my servo went bad, it was just a loose connection
