Dealer says I need a new throttle, $895.00
Discussion in 'Gen 3 Prius Technical Discussion' started by deewayne, Jul 23, 2019.
  1. deewayne
    deewayne Junior Member
    hickory nc
    My 2010 with 160,000 miles laid down and had to be towed, check hybrid system and various other warnings came on and the car stalled in the hiway. Towed to a reputable independent shop and they installed a new 12 volt, with my permission,after testing my original battery. Now they say it needs a throttle, they didnt give me the code, but they got the car to move on its on a little bit in the parking lot but then it quit again. So I towed it to a local Toyota dealership for diagnosis and they also said it needs a throttle. It doesn't seem to be a common problem. Any suggestions would be helpful
    48,946
    it's not, as far as i remember. not sure what part is the 'throttle' exactly. did the dealer charge you? if o, they owe you the codes
    if you go for it, don't pay them until they take you for a drive
    deewayne likes this.
  3. Mendel Leisk
    38,214
    McGeorge Toyota will sell you a throttle body for $387 plus shipping.
    2010-2018 Toyota Throttle Body 22030-37060 | McGeorge Toyota Parts
    Assuming that's what they're talking about, it's a fairly easy swap, about an hour. You need to disconnect and reconnect a couple of coolant hoses.
    I can post some info with torque values in a bit.
    mikey_t and jb in NE like this.
  4. Mendel Leisk
    38,214
    Watch @NutzAboutBolts video on intake manifold cleaning, pinned in the 3rd gen maintenance forum. In the process he removes the throttle body. In the attached are torque values for the throttle body hold down nuts/bolts (2 of each).
    NutzAboutBolts and deewayne like this.
  5. deewayne
    hickory nc
    I am not very mechanically inclined, I have been told a prius is dangerous to work on if you don't know what you are doing. I think my biggest issue is not seeing this as the real problem. guess I won't know until they do it? This car has been down over three weeks now(we were on vacation) and I am wondering if this will cause an issue with the hybrid battery?
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,782
    2017 Prius c
    There is no single part that is designated " the throttle".
    Some clarification is needed.
  7. fotomoto
    fotomoto Senior Member
    5,597
    3,771
    So. Texas
    I'm thinking the TPS (throttle position sensor) may be out, or out of spec/adjustment.
  8. jerrymildred
    jerrymildred Senior Member
    11,491
    14,100
    Tampa, FL
    Yeah, just "throttle" is too vague to know what part you'd need to get.
  9. deewayne
    hickory nc
    the service writer said, the throttle body is stuck, The part is $585
    #9 deewayne, Jul 24, 2019
    bisco and jerrymildred like this.
  10. Mendel Leisk
    38,214
    Yeah then it is the part linked in post #3. It is really not that hard to do. Watch the videos mentioned in post #4, to get a feel for what's involved. To get to it you need to remove the air box and snorkel, which is shown in the EGR pipe cleaning video. Removal of the throttle body is shown in the Intake Manifold cleaning video, IIRC.
    You need a ratchet wrench, a 3" and 6" extension, 10 mm socket, long reach needle nose with bent tip, and a 1/4" torque wrench, probably with a 1/4" to 3/8" adapter (for the throttle body hold down bolts/nuts).
    With your miles it would be good to replace the gasket too.
    #10 Mendel Leisk, Jul 25, 2019
    mikey_t, deewayne and jerrymildred like this.
  11. jerrymildred
    11,491
    14,100
    Tampa, FL
    There ya go! That's specific. (y) The Prius has some stuff that more primitive cars don't. But a throttle body is a throttle body. It's not that hard to replace, as @Mendel Leisk pointed out. Any car can be dangerous to work on if you're careless. Basically, stay away from the orange high voltage cables and the stuff they are connected to and it's no more dangerous than a gasser. There are Youtube videos for almost everything.
    mikey_t, deewayne and Mendel Leisk like this.
  12. fotomoto
    5,597
    3,771
    So. Texas
    It simply may be gunked up from a lifetime use of dirty gas and air (air filters aren't even close to 100%). I had one begin sticking on a RAV4. A few minutes with throttle body cleaner and soft rags and it was working like new again.
    Worse case scenario that it is indeed bad; find a good used throttle body and have an independent hybrid shop install it.
    #12 fotomoto, Jul 25, 2019
    jerrymildred, deewayne and Ed Beaty like this.
  13. Mendel Leisk
    38,214
    Yeah I'd be inclined to just dig down to it, give it a cleaning without even lifting it off it's base on the intake manifold. See @NutzAboutBolts video #14 here.
    For a more thorough cleaning, remove the hold-down bolts/nuts, the electrical connector, and lift the throttle body off (leave coolant hoses attached), and clean from both sides. Alway apply carb cleaner to a cloth or q-tip, apply carefully. Torque value for those nuts/bolts is 7 foot/pounds (per the attachement in post #4). A 3/8" or 1/4" torque wrench is optimum for those values, preferably 1/4".
    Look into the intake manifold while you've got the throttle body off the intake manifold too: I think you'll be taken aback by the gunk lurking in there. One of the bug-bears of 3rd gen is the Postive Crankcase Ventilation's propensity to dump sludge in the intake manifold.
    At the least swab out what you can reach, and disconnect and pull off the Manfiold Absolute Pressure sensor (around 3 o'clock on the intake manifold, at the throttle body mounting base. Spray it with CRC MAF sensor cleaner, and gently brush with q-tip.
    Something else you very likely need to be address, and may be a factor: with that amount of miles the Exhaust Gas Recirculation is likely well along in it's clogging. This involves the intake manifold as well. Some info:
    The simplest way to see where you're at, is to check the degree of carbon build up in the EGR pipe, a stainless steel connecting pipe between the EGR valve and intake manifold. Watch @NutzAboutBolts video #16 here:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    Two or three other videos linked there too, for the full cleaning of the intake manifold, full EGR clean, and Oil Catch Can install.
    Good thread:
    EGR & Intake Manifold Clean Results | PriusChat
    Another:
    Oil Catch Can, Eliminate that knock! | PriusChat
    Somewhat tools worth having:
    E8 Torx socket (mandatory)
    E6 Torx socket (optional, but good to have, to remove the throttle body studs from intake manifold)
    3/8" ratchet wrench, regular and long handle, flex head, you can never have enough
    1/4" ratchet wrench, or 3/8" to 1/4" reducer
    Ratchet extensions: you can never have enough
    Long needle nose piers, straight and bent tip
    Ratcheting 12mm box wrench (optional, but makes disconnection of the EGR cooler from exhaust easier)
    Torque wrench (3/8" and 1/4" both good to have)
    Floor jack and safety stands (or ramps): basically some method to raise front, if you need to take underpanel off, which you may need to, both for access and to recover dropped items.
    Some EGR info from the Repair Manual attached:
    #13 Mendel Leisk, Jul 25, 2019
    mikey_t, CR94, NutzAboutBolts and 2 others like this.
  14. ETC(SS)
    6,492
    Whoever told you that "a prius is dangerous to work on if you don't know what you are doing" needs to have their 'listen to' privileges revoked by you, not because this wisdom is especially untrue, but because somebody is obviously using FUD to scare you.
    ALL cars are dangerous to work on if "you don't know what you are doing." but that does not mean that you shouldn't be working on them for the very reason that ALL cars are dangerous to DRIVE if you don't know what you're doing.
    The reason that ladders have more stickers on them than Subaru bumpers in Vermont is that manufacturers have to put them on because ladders are dangerous if you don't know what you're doing....and because their legal department and dot.US.gov requires them to do so.
    So....
    1.) If you wish to remain mechanically uninclined, it's gonna cost you.
    I'd pay the dealer to swap out the TB and eat the $500, because putting miles on tow trucks is expensive too.....besides....there's a difference between a 'trusted' independent mechanic and a competent one. I think that they should have detected the TB trouble myself....so.....
    B.) Start looking for another trusted mechanic.
    III.) Based on my Prius ownership experience the hybrid (traction) battery should not be deteriorated by a 3-4 week slumber, presuming whomever fixes this problem thoroughly op-tests the car following the repair.
    Four.) If you do NOT wish to remain mechanically uninclined, it's also gonna cost you, but not nearly as much as you think, and 'uninformed' might be more descriptive. One of the really groovy things about living the 2020 life is that you effectively have access to much of the sum total of human knowledge in your hands every day.
    With a little bit of time and effort, you can be a MUCH more informed and effective consumer of automotive maintenance and repair (they ARE two different things!)
    With a little bit of time and effort and $100 worth of Harbor Freight tools you can DIY nearly everything needed to keep your car or truck on the road for it's normal service life.
    or?
    You can continue to look at automotive maintenance and repair as a regrettable inconvenience and let others decide when, where, and how your car is serviced.
    There are advantages to each approach.
    Life is short, and some people simply do not want to be 'bothered' with car upkeep.
    Time or money.....
    Me?
    I don't have a choice. ;)
    YMMV.....
    Good Luck!!
    #14 ETC(SS), Jul 25, 2019
  15. deewayne
    hickory nc
    Great info from everyone, Thanks, I haven't done anything yet, but I will keep you posted.
  16. deewayne
    hickory nc
    OK, I went by the dealership today and told the service writer I was going to just pay the diagnostic fee ($102.15) and try to repair it myself. she said that was fine. I gave her my credit card and she left the area then came back with my receipt. Then a guy pulled up in the service bay in my car and gave me the keyfob. Now I am surprized by this because I had to tow the prius there and expected to have it towed it home today. Then she said "I told you he got it running a little bit." This was true but her tone gave me the impression the car was drivable or repaired at all, and that was over the phone when she called to tell me the diagnosis from the tech. I did not put up a fuss, I'm just happy its moving on its on. I just got home, 8 mile drive and no codes. Every thing seems fine. After much reading here I am now thinking the codes just had to be cleared from replacing the 12 volt battery at the first shop and they just didn't know how to do it properly or maybe the tools to do it? IDK anyway,This is what the service ticket from the dealership had on it,
    "Ran codes found P2111 throttle actuator control system stuck open, parts and labor $759.00"
    Should I be concerned about this happening again? If there are any further developments I will post. But I've got a good feeling about this being over at least for now. Thanks for Listening and giving me all the good advice hopefully this will help others in the future.
  17. jerrymildred
    11,491
    14,100
    Tampa, FL
    Unless they cleaned it, it’ll stick again. Actually my first thought was that it just needed to be cleaned. But I assumed (oops!!) that if the dealer said it needed to be replaced that they had already tried cleaning or that they saw something broken. I recommend a can or two of TB cleaner and maybe use some MAF sensor cleaner while you’re in there. These should be YouTube videos to help you out.
  18. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    I have a spare TB with low miles that I took off my car.
