Dealer says I need new break pads
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mbredehoft, Mar 11, 2015.
  1. mbredehoft
    mbredehoft Junior Member
    Wisconsin
    I have a 2010 Prius III with 46000 miles. The last time I had it into the dealer they rotated tires and told me I needed new brake pads and the front rotors needed to be ground down or smoothed from pitting. I think that 46000 miles is way to soon to need brake pads. I think the dealer may be trying to milk me for some un-required work. I am going to get a second opinion from a place I usually get tires. Any other advise?
    The Electric Me likes this.
  2. jdenenberg
    jdenenberg EE Professor
    3,852
    1,845
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My dealer told me that my 2004 Prius needed a full brake job at 100k miles, I pointed out the error of their ways to the service manager. I am now at 270k miles on the original brakes.
    JeffD
  3. Munpot42
    Munpot42 Senior Member
    1,391
    543
    Santa Monica, Ca. 90405
    Have good independent shop check your brakes, really should be waaaaay tooooo soon for a brake job.
  4. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Unless you are stop and go with less than 7mph speed driving those 46K miles, it is highly unlikely. It is possible due to mechanical problems, like a stuck bit causing the brakes to be engaged all the time, but you should have noticed a super drop in mpgs.
    You could just look at them through the wheels. Not that hard to see.
  5. bisco
    49,446
    in some wintry climes (wisconsin:)) 2010's have been prone to early brake wear due to sticking slide pins. i would ask your tyre shop to show you the rotors and pad thickness.
  6. bestmapman
    bestmapman 04, 07 ,08, 09, 10, 16, 21 Prime
    1,289
    242
    Kentucky near Cincinnati, OH
    It seems early as I have 190,000 on the original pads. But, have it checked out as your driving commute or circumstances may have worn them out earlier than most.
  7. Mendel Leisk
    38,709
    With just the scissor jack you could raise one corner, remove the wheel and see how much thickness is left on the pads. Outer pad is readily visible, inner pad can be viewed edge-on through an opening on the caliper. Both have a slot, makes it easier to identify.
    Pad thickness is "net", doesn't include backing plate. Brand new they're around 10 mm, minimum is 1 mm. Anything near 1 mm, it's not worth stalling.
    Some caveats: loosen lug nuts slightly before raising the car. Lug nut torque is 76 ft/lb.
    Still, if you really mistrust your mechanic, not a good situation.
  8. Former Member 68813
    3,524
    981
    US
    that happens also in balmy subtropics too. apparently toyota factory workers don't grease them well at factory.
    BTW, what are break pads?
  9. ETC(SS)
    6,553
    You don't need new pads unless you drive like an idiot.
    I'd be willing to guess that the rotors do not need to be resurfaced either.
    What you probably need is a new dealer.
    OK....
    So....you live in the frozen North and you may have some corrosion issues that I don't have living by the Gulf.
    Get a second opinion from a mechanic.
    If I'm right, you need to tell Toyota that they have crooks running one of their stealerships up in WI.
  10. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    I could look, but you are closer.
    #10 SageBrush, Mar 12, 2015
  11. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    I liked your post because you misspelled Brake Pads in the title, but then spelled it correctly in the post.
    I use to do that in grade school, just to keep the teachers guessing.
  12. SageBrush
    11,627
    2,530
    Southwest Colorado
    I'm under the impression that titles can now be edited
  13. Mendel Leisk
    38,709
    Say dealership said your oil was low, whadya do: take a survey on the net, or check the dipstick?
    Pad thickness check is a bit more involved, but still the shortest distance to a conclusion. If you really don't want to check them, ask a second mechanic to verify.
    #13 Mendel Leisk, Mar 12, 2015
    CR94 likes this.
  14. Sfcyclist
    Sfcyclist Senior Member
    1,621
    375
    SF, CA
    As everyone mentioned already.. don't take their word for it.. during my visits under factory covered maintenance, they didn't really check or performed serviced noted. Tires pressure, tread depth, oil and tire rotations were not done.. I knew because I checked myself..
  15. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    Does your car get parked under cover or does it stay outdoors all the time?
    It's possible that the brakes aren't bad but it's also possible that they are, considering your location. Don't let people from outside the rust belt tell you this stuff.
    Get a second opinion. Hint--> the worst rotor rust is usually on the hidden side.
