Dealership 95k Service
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Brad K, Feb 28, 2019.
  1. Brad K
    Brad K Member
    168
    53
    Took it to the dealership for the 95k service, $19.95 before taxes for tire rotation. They tell me that both filters need replacement, I laughed and said that was done at the 90k service. They checked and said I was correct. It was a leftover recommendation from the 85k service.
    Then they recommend cleaning engine carbon deposits for $164. I said no. Maybe next time (is this something that is needed or that is common?
    I asked about the 100k service. Said it involved flushing the coolants and maybe some other things, perhaps $260ish!
    Is that necessary? None of this is in the recommended service by Toyota!
    49,505
    No, follow the manual. If c has egr, that should be cleaned.
    Maybe consider tranny fluid.
    There will be compete fluid replacement coming, not cheap
  3. Brad K
    Brad K Member
    168
    53
    what is egr?
    no fluid flushes are in the owners manual?
    49,505
    Exhaust gas recirculating, see nutzaboutbolts YouTube channel.
    Maintenance schedule should show coolants and brake fluid at 120k?
  5. Brad K
    Brad K Member
    168
    53
    Initial engine coolant replacement at 100,000 miles/120 months. Replace every 50,000 miles/60 months thereafter. Initial inverter coolant replacement at 150,000 miles/180 months. Replace every 50,000 miles/60 months thereafter.
    bisco and Mendel Leisk like this.
  6. Brad K
    Brad K Member
    168
    53
    at 120K:
    • Replace Engine Oil And Oil Filter
    • Replace Spark Plugs
    • Replace Engine Air Filter
    • Replace Cabin Air Filter (If Equipped)
  7. Mendel Leisk
    38,735
    Sounds like you're on top of it. (y)
    One comment: I would revise all these filter "changes" to "inspections", do them yourself, and only replace filters as warranted.
    Brad K likes this.
