Dealership changing given modules in HV pack without informing owner
Discussion in 'Gen 2 Prius Main Forum' started by BLNT, Jun 24, 2020.
  1. BLNT
    BLNT Junior Member
    37
    Hungary
    I have a 2005 with 140k miles. Bought it used a little over a year ago.
    ABS actuator, front-rear brakes, 12V battery, regular water pump needed changing.
    The inverter coolant pump was changed via the recall.
    The car started its journey in Denmark where it was only first registered in 2008. It must have been a saloon car. Then it was exported into the Netherlands from where in 2014 I believe was exported to Hungary, where I bought it from the first owner.
    Since its was first registered in 2008, it still had the hybrid battery warranty until 2019 May period. And here is the kicker.
    I had the bus bars changed as maintenance in an independent hybrid shop in 2019 June and we saw something very strange. There were marks on some of the modules of the HV pack, indicating, some of them were changed. But how could that be, if there was a live warranty for the pack at the time?
    The pack was not brand new that would indicate a complete pack change by Toyota.
    I know the previous owner did not do anything to it and he had been doing the yearly HV battery warranty check for the car at the dealership, to get the yearly warranty for the pack until the car's 10th year of registration that ended in 2019 May.
    The independent shop owner said that Toyota themselves could be changing given modules that might fail in the near future based on the voltages at the yearly checks, in order to keep up the great PR of hybrids. In general, the packs might fail before 10 years that would in general hurt their PR. But that's just a theory.
    Has anybody heard, experienced something similar?
  2. PriusCamper
    PriusCamper Senior Member
    11,106
    4,520
    Pacific Northwest, USA
    There's some sharpie pen markings on the sides of Gen2 Prius that were put on their during original assembly in Panasonic factory that often make people think work has been done on the pack after the car was first purchased. So don't get fooled by that. The real way to confirm all your modules are original is the serial numbers on top of each module. The first letters and numbers in the serial # is code for month and year of manufacture. As long as all those are the same on all 28 modules, you're still running with original pack.
    MickyMatter likes this.
