Dealership pulled up a stored C1202 code during a pre purchase inspection
Discussion in 'Gen 3 Prius Main Forum' started by mattbatson, May 16, 2019.
  1. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    So I'm purchasing this 2011 prius with 147k miles...or I was...after a hopefully smooth inspection from the local Toyota dealer.
    So they take us back into the bay with the car up on the lift and show us a section of rocker plastic panel under the car, about 8 inches in length that is missing. Quoted me like 500 dollars to replace it...which I know is a joke.
    But then they said they found a stored code in the ABS system of C1202 which is brake reservoir fluid level sensor...or some such.
    Said for 144 bucks they would investigate. Said probably something needs to be fixed but don't know what or how much.
    Should I be worried and bail on purchasing the car?
    52,625
    was the reservoir full?
  3. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    yes.
    seller has experience with cars/mechanics and said the level has always been full...never had to add any brake fluid in the year that he has owned it.
    the Toyota mechanic indicated that there may be a problem with the level sensor...but did not indicated any leaks or other issues with the brakes
  4. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    If they can give you at least 30 days of warranty, that should be enough for an existing brake problem to show up. For most of the past 100 years drivers didn't have brake fluid sensors, and they just looked at the reservoir to see if the level was OK.
    jb in NE likes this.
  5. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    This is pretty much what I also thought, but was a little unsure. I'm not sure if the private owner will give a 30 day warranty on the brake reservoir but I'll ask
    thanks!
  6. bisco
    52,625
    i'm not sure how the code is set without a dash light. maybe clear it and see if it comes back
  7. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    Run!!! Too much miles for a pre 2012, money pit later.
  8. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    hey Grit...
    could you elaborate?
    what sort of issues can I expect with over 147k miles on a 2011 prius?
    are they more reliable after 2012?
  9. bisco
    52,625
    oy, i figured you already knew :oops:
    mattbatson likes this.
  10. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    So the owner said he had checked for engine codes with his scangauge and saw none...I think from what I'm understanding is that this code was maybe something, somewhere, that a regular code scanner would not see?
  11. mattbatson
    mattbatson Member
    114
    82
    asheville NC
  12. Mendel Leisk
    42,114
    yeah google the part number:
    51410-12105
    (Assuming it's the main engine underpanel)
    The part is around $200 on Amazon.
    Some more info in the attached:
  13. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    Thanks!
    but it isn't the main engine undertray...it is literally a 8inch by 3 inch plastic piece under the rocker arm...passenger side...about where the front and rear doors meet. Probably have to either order from Toyota or find one in a junkyard. But honestly it didn't look like a big deal to me. They were saying water would get up in there. But I put my hand up there and is just the underside of the body. Not thinking water up in there would matter.
    So are 2011's inherently unreliable compared to 2012's
    I have a couple of friends with higher mileage 2010's...one has 223K miles on it...and they have done nothing but oil and air filter changes and maybe spark plugs and such...?
  14. bisco
    52,625
    many prius codes only show up with special scanners
  15. bisco
    52,625
    i was going to let grit tell you. the best thing to do is search egr circuit, oil burning and head gasket.
    there are a lot of problems around 100k, but we don't know what percent of ben 3's or why
  16. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    ah yes,
    I was familiar with that. For some reason I thought it was not that common...but had planned on doing the egr cooler clean at some point on the car. It seemed like a safe choice so long as the egr was cleaned every 100k miles.
    thanks
  17. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    See post #15 and remember it well.
  18. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    Majority of those who purchase the car with low miles or new, take great care of their car, drive conservatively and follow maintenance schedule religiously will have a reliable car in the long run.
    But this one your buying with higher mileage are showing red flags, they could have driven it recklessly.
  19. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    Hang around here long enough, you'll see people post things sellers claimed to do such "The seller said he changed the spark plugs recently." When the engine knocks and they look at the plugs, they go "The plugs needed replacement, it wasn't even replaced at all like the seller said."
    You can pull the 12v bat and all codes will be gone, of course no codes when scanned. What you need to do is scan to see if all monitors are online first, then if there are no CELs after that then your clear.
  20. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    Did your head gasket blow?
