Dealership wouldn't honor 12v warranty because it was replaced under 336 basic coverage?
Discussion in 'Gen 4 Prius Main Forum' started by Halcykon, May 26, 2024.
  1. Halcykon
    Halcykon Junior Member
    29
    Sugarland
    2018 Prius
    TLDR: Toyota won't honor the Truestart 84-month warranty if it wasn't explicitly purchased? Did anyone else have this issue?
    Timeline of events:
    08/2018: Purchased new car (2018 Prius, Trim 2)
    10/2019:
    12v battery started having issues (low voltage)
    04/2020: Dealership replaced battery for free under the 3 year basic coverage warranty. I was told that the Truestart 84 month battery warranty would still work.
    05/2024
    : 12v died. I called the dealership and they said they would honor the warranty at the prorated amount. I went in the next day and after 2 hours of tests, they came back and said that while the battery is definitely defective, they couldn't honor the warranty because it was replaced under the 336 warranty, not purchased.
    This exception is not stated anywhere on any official Toyota material (TOYOTA WARRANTY POLICY & PROCEDURES, Toyota Warranty Information). However, the dealership would not budge, and the representative I called from the national Toyota hotline also had no idea).
    I'm curious if anyone else has had this experience.
    #1 Halcykon, May 26, 2024
  2. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    Typically OEM replacement parts carry a 12 month warranty.
    4 years on a lead-acid battery in Sugarland, Tx is not abnormal.
  3. fuzzy1
    10,170
    It would seem abnormal for a free warranty replacement to extend the life of the original warranty. So I would ask:
    1) did the person who stated that they'd honor the replacement's longer warranty, properly understand the question or the context?
    2) did above person have sufficient business authority to say that?
    3) if none of the above works, will Johnson Control / Interstate Battery, the apparent maker of Truestart batteries, separately honor the 84 month warranty?
    If none of the above work, well, it isn't like you lost anything that you actually paid for. A free gift just didn't turn out to be as good as expected, but still performed its primary job well beyond the original factory warranty. There is no real injury here.
  4. Mr.Vanvandenburg
    1,064
    370
    2020 Prius Prime
    It’s easy to get wrong information on the phone, half the time they aren’t even listening. It seems like that’s how it works, as you have no receipt for the second battery, and the warranty on it was for three years.
  5. rjparker
    rjparker Tu Humilde Sirviente
    7,975
    4,716
    Texas Hill Country
    it would seem a prorated 84 month/7 year warranty would still apply even if it was calculated back to the vehicle purchase date. At least through 2025. It might be a $30 credit for 14 months remaining unless installation or other fees like disposal cancels it out.
    I might try another dealer. Toyota does not require using the same dealer.
