Dealing with the Prius in serious snow and ice...
Discussion in 'Gen 3 Prius Main Forum' started by PriUsr, Nov 7, 2012.
  1. PriUsr
    PriUsr Junior Member
    28
    New York
    Would anyone like to share advice on the best methods for driving the Prius in winter conditions?
    Ah… such a disappointment I received tonight when my Prius couldn’t make it up my driveway. It’s just a slight incline; I didn’t expect the car to fail so miserably. I had to leave it on the side of the road, looking pathetic. It was such a delight for my neighbor.
    48,862
    my driveway is also a slight incline. i have no problem at all. drove to work in a nor'easter today. didn't have any trouble, sit low and drive slow.:cool:
  3. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    I had a set of Michelin X-Ice winter tires mounted on my factory wheels. I accelerate very gently to avoid all wheel spin. The traction control detects spin and severely cuts power to avoid damage to the electric motors. If you need to get up a sloped driveway, slow and steady wins the race. Attempting to power up a slope will result in parking at the bottom.
  4. harper42
    harper42 Member
    226
    I had a set of x ice on my 2006 and they were great. I just got a new set of alll season Hercules tires. Hoping they get me through the snow ok. I live at the top of a hill. Prii do not like tire spin....
  5. TN Traveler
    TN Traveler Member
    32
    31
    I would think it would do as well as any small front wheel drive car, especially when you use eco mode as this softens throttle input, I guess I will find out this winter as my weekly commute includes I77, Fancy Gap in SW VA known for it's snowy nights.
  6. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Get real snow tires if you live in an area that gets snow. It's not just forward traction you have to worry about. ;)
  7. Judgeless
    Judgeless Senior Member
    1,821
    255
    Cleveland, OH
    I have had my 2010 Prius for 3 winters now. With snow tires it performs better then my 4 wheel drive Toyota 4Runner.
    markabele likes this.
  8. HEKTOR
    HEKTOR Junior Member
    16
    Westfield MA
    I wanted to start a post on my 1st experience in driving on snow and ice and can say that I'm impressed in the way it handled, one note is that I changed the OEM tires for a set of 17" Hancook Ventus and new rims and drove like a AWD...not sure how it would have been w/ the stock tires...they look cheap..
  9. cwerdna
    cwerdna Senior Member
    12,544
    2,122
    SF Bay Area, CA
    I suspect the OP doesn't have snow tires.
    I agree. It seems many of the complaints about snow and ice performance are from people using stock tires.
  10. OceanEyes
    OceanEyes Active Member
    527
    424
    Southeastern Connecticut
    Wait, what? Better than four wheel drive (with snow tires) And what kind of snows do you have on yours?
    I am a newbie so please, please educate me - with snow here in CT my Prius has the day off and I am taking the truck in as I have visions of someone smacking into me as they learn their winter driving skills all over again...(oh, and visiting the diesel pump with the big girl was not pretty after not taking her out much...)
  11. harper42
    harper42 Member
    226
    My first Prius was a 2006. I put Michilin X-Ice tires on her and I always called her my little snow machine. I'm in central Indiana, live on a decent hill, and we get some good snows. Never a problem. BUT with the tires that come on the Prius, you might have problems. The car DOES NOT let the tires move if they start spinning. Get Snow Tires.
    OceanEyes likes this.
  12. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    4Wd doesn't help you stop and the light rear end makes overstear worse. So unless you need ground clearance they newer Prii with good snow tires are more than sufficient.
    I noticed either your Fuelly report is wrong or you have a plug-in model that's not listed in your sidebar information. To ensure fuelly is as accurate as possible can you fix you tank report? :)
  13. Agreed. Accelerate very gently, otherwise the wheels break loose and you'll lose momentum. I know I don't have snow tires but you get the idea w/ the video I posted in this thread (ECO mode helps if you have a lead foot).
    Continential DWS performance in the Snow (video) | PriusChat
  14. Vas25tl
    Vas25tl Member
    268
    77
    Milwaukee
    I'm ordering my Michelin X Ice 3's on a set of alloys this week. I already put my dunlop snow tires on my Scion.
    I'll be ready!
    F8L likes this.
  15. David Beale
    David Beale Senior Member
    5,963
    1,979
    Edmonton Alberta
    With proper tyres Pearl is more stable than my FJ Cruiser. Low and light. Pearl S is still wearing the stock tyres, and is parked snugly in the garage. I'm driving the FJ and using up all that surplus gasoline. ;)
    Pearl had Nokian WR tyres, which work well in ice and snow and don't wear excessively in summer. Pearl S will be getting those eventually. Mainly because they also make the car more aquaplaning resistant. I don't plan on driving Pearl S in snow such as today. I feel if I have to plow the streets I should be also getting $150 an hour (or more) from the city like the other snow plow contractors.
  16. Sergio-PL
    Sergio-PL Member
    160
    46
    Poland
    My Prius performs great in winter too. It likes snow at least on Goodyear Ultragrip winter tires.
    Hints:
    1. Accelerate gently
    2. If you know you want to get most of the grip and accelerate as fast as possible apply acceleration gently until VSC lamp start to blink and then floor it. VSC will moderate acceleration to keep best possible acceleration depending on the ground conditions
    3. DON'T floor it from stand-still on slippery road. If you do it and VSC will not react fast enough to limit wheel slip your electric engine will desynchronise and you end up with about 0.5 sec of total lost of power. You can avoid it meanwhile accelerating fast by using technique from point 2.
    4. When braking - keep in mind that even on the best tires you need form 2 to 4 times more road length than on dry conditions
    5. ABS braking on prius feels a bit different. It will not knock you on the foot while working as it is typical to normal cars.
    6. Loss of brakes feeling. You can google it on this forum. When you brake first part of braking is using only electric brakes. If for any reason ABS or VSC must work (one wheel sleep, hit the road hole/bump) Prius will switch to friction braking. Many people feel this switch as a short loss of braking power. Also brake pedal feels slightly different then. But car will stop anyway. It's only user feeling. Unconsiously you just apply brakes harder and everything goes fine.
    And that's all. Prius drives on the snow just as any other car. It has a bit lower ground clearance so keep it in mind and you'll be fine.
    OceanEyes and Vas25tl like this.
  17. Daryl K
    Daryl K Member
    103
    45
    My drive is a pretty steep incline, but I have a set of four General Altimax Arctic tires (in black-painted steel wheels) and have zero problems. It's superior to my Subaru Outback with all seasons on (but when I put her snow tires on she's unstoppable).
    As others have noted, if you live where it snows, get snow tires. Preparation is more than key, it's essential to your safety. In the 30+ years and 1.5+ million miles I've accumulated (on many cars, not just the Prius - LOL) I cannot count how many times I've braked and driven around cars pirouetting off the road (or onto their roofs) in winter because of a refusal to get proper snow tires.
    Since the late 80's I've always bought my snows as a bundled set of four, balanced and mounted on steel wheels, from Tire Rack. This way I can swap on and off on my own, for free, in about 30 minutes (every fall and spring).
    Sorry if I sound like an ad for Tire rack, but I don't work for them. Just a long-term happy customer.
  18. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    You could try backing into your driveway- sometimes that works with FWD cars... our tenant used to use this method with her FWD Hundi wagon (with almost bald tires) when she couldn't get up our driveway going forward due to snow.
    I'll have the rims for my X-Ice snows on Saturday, but I drove the PIP on the stock all season tires last night during our nor-easter. The LIE was pretty snotty with a nasty mix of packed ice, slush and puddled water. If nothing else the PIP was predictable- I give it a rating of acceptable with the all season OEM tires. Can't wait to see how she handles with the X-Ice snows... since 2003 I've been driving a AWD CR-V, this is the first winter in a FWD car in a long time....
  19. Cyen
    Cyen Junior Member
    Hello all.
    New Prius owner here. This post interests me, in that I've always driven a toyota 4x4 pickup (for the last 22 years anyway) and never had a problem in the snow. It's one of my fears being a new Prius owner = snow. Question to those who have the snow tires: Do you suggest getting all 4 new snow tires or will 2 in the front suffice?
    It'd be great to see a poll on the brands of snowtires you all have too. Looks like the Mich X-Ice are popular.
    Thanks all
    Cyen
  20. car compulsive
    741
    274
    Michigan
    ^^^ Winter tires on all 4 corners.
