Dear Consumer Reports
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, Mar 2, 2009.
  1. bwilson4web
    15,511
    While comparing your top rated car against the Prius, I was surprised to discover that your Prius safety specifications report:
    "Daylight running lights - not available"
    (see attached PDFs)
    This may have impacted both the Prius "base" score of 68 as well as the Prius "Touring" score of 80. I've attached copies of printed output from your web site for both vehicles. Yet I too was surprised to find the Toyota Web site does not list "Daylight running lights" under the Prius specifications.
    I like every other Prius owner, have frequently seen our daylight running lights in operation. I would suggest one of your evaluators go to the Prius, start it up, and while it is in park, go to the front of the car and observe the headlights. I suspect the 2004-2009 Prius owner's manual includes some reference to this feature. Did anyone look? Did no one notice that every Prius on the road in the daylight has their head lights on?
    I look forward to seeing a correction and new scores for the existing Prius as well as avoiding a similar problem with the new 2010 Prius. We are also sending a copy of this note to Toyota America with a suggestion that their web page specifications add the "daylight running lights" as standard equiment.
    Thank you,
    Robert J. Wilson
  2. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi Bob,
    My 2006 does not have the sensor installed, nor does it have the auto-daylight running light feature. The Canadian cars do, as its a legal requriement there.
  3. Patrick Wong
    18,200
    6,471
    Hi Bob,
    US 2G do not have DRL.
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Yea Bob, unless you've just been hanging out in Canada the rest of NA doesn't have DRLs...hope you haven't sent that letter yet.
  5. bwilson4web
    15,511
    Well, I stand corrected. I did a quick pass through Google images only to discover the Canadian photos show the headlights on but the USA photos don't.
    I'm surprised because my NHW11 has daylight running lights. I am surprised and disappointed. Now I wonder if the 2010 has them only to discover I can't find them.
    Have daylight running lights gone passe as a safety feature?
    No, I hadn't sent the letter, I typically do a draft, but now I'm seeing a different set of questions:
    • Are daylight running lights an effective safety feature?
  6. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    For a while there I thought I was on drugs or ....
  7. msirach
    msirach Member
    321
    Southern Illinois
    Who wants daytime running lights? Do you leave your outdoor lights on at home during daylight? Daytime running lights are energy hogs that use up battery power with an end result of added fuel consumption.
  8. Boo
    5,051
    483
    97
    Flushing, NY
    I like DRLs. I think it's easier to see cars with DRLs.
  9. bwilson4web
    15,511
    Well I was able to find an NHTSA report (see attached):
    • DRLs reduced opposite direction daytime fatal crashes by 5 percent.
    • DRLs reduced opposite direction/angle daytime non-fatal crashes by 5 percent.
    • DRLs reduced non-motorists, pedestrians and cyclists, daytime fatalities in single-vehicle crashes by 12 percent.
    • DRLs reduced daytime opposite direction fatal crashes of a passenger vehicle with a motorcycle by 23 percent.
    Well this explains why it has been treated as of marginal value. Having been a motorcycle and bicycle rider, I'm a great believer in having lights. So I'm surprised that they are not more effective.
  10. fuzzy1
    10,149
    My house is extremely unlikely to suffer a collision caused by a driver failing to see it due to adverse lighting conditions.
    My car's risk of such events is orders of magnitude higher.
    Energy hog? That is why we need LEDs.
  11. PriuStorm
    PriuStorm Senior Member
    2,239
    149
    Davis, CA
    Bob ,
    Not sure where you found those stats, but I'd be interested to know how the stats are for Europe. I think the scandinavian countries were one of the first to require daytime lights (everyone know those scandinavians usually do things for a good reason ;) ). Of course, the roads are very different over there... they are narrow, twisty and windy farm paths that have been paved and turned into roads, with ancient oak trees near the roadways and drivers often encounter each other in blind swings as they navigate the roads that often aren't even painted with lines. That's not to say that they don't have long straight stretches of highways, but they often have grey weather as compared to some local climates here that enjoy long stretches of clear sunshine.
    In any event, is the automatic/off feature of the Prius not considered DRL? I mean, I leave my lights on, but when I exit the vehicle, they turn on. Then when I fire up the vehicle again, the lights are automatically on. Does this not count as a DRL?
  12. Patrick Wong
    18,200
    6,471
    The 2010 Prius Product Information datasheet does not list DRL as a feature, so I hope it is OK to tell you that the 2010 vehicles that I saw yesterday do not have DRL.
    No. DRL is not the same as the auto off feature. DRL implies that only the headlights (high beams at a reduced intensity for example) or the front turn lights (some GM vehicles are examples) are on. The auto feature implies that all exterior lights are on except high beams.
  13. bwilson4web
    15,511
    Well it looks like insurance company discounts are not universal. However, the Insurance institute reports:
    So I'm of mixed opinion. It looks to reduce the accident risk but if this does not translate to a lower premium, I tend to lose interest.
  14. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    I know that California law is lights must be on if the windshield wipers are working, thats a new law I believe that most people have no clue about.
    Also, when I am driving my work truck (F350 Ambulance) headlights MUST be on at all times regardless of time of day or brightness. Has to have some sort of safety link. Heck, even Pizza Hut has a sign in their store stating "Lights on For Safety" for its drivers.
    I guess if you wanted DRL's on the Prius, you could leave them on and allow them to just go on and off as you start/stop the vehicle.
  15. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Unfortunatly DRL's are needed because a lot of people are idiots and don't know to turn their headlights on when it's foggy, rainy or other condintions causing bad visibility.
  16. kenmce
    kenmce High Voltage Member
    1,527
    502
    NY
    You're talking about central New York, right? :rolleyes:
    That's what I do, and I believe it is considered a little bit less effective than "real" DRLs. I have altered my decorative fog lamps to assist with DRLing too.
  17. patsparks
    10,664
    567
    Adelaide South Australia
    DRLs use less power than a crash repair shop.
  18. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    Some of the 2010's did have DRL in the facia, others treated them as turn signal indicators.
    The 1G had DRL as an *option* in the US (which I paid for).
  19. NYPrius1
    NYPrius1 Active Member
    1,181
    125
    Middletown, NY
    I Agree!! Also in bad weather rain etc.
  20. NYPrius1
    1,181
    125
    Middletown, NY
    I think the Law in New York is the same... Lights on when wipers are on.
