Death triangle with abs lights
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by John trapp, Jun 4, 2019.
  1. John trapp
    John trapp Junior Member
    Hyannis
    08 with 114k triangle of death and abs lights come on when you drive about 20 miles pulled abs codes c1241 and c1310 checked battery was only 11.6 volts and replaced no ck engine codes a/c does not work and full of freon if I disconnect battery get about 20 miles before lights come on car drives fine hybrid working any ideas where to look
    49,500
    inverter pump?
    SFO likes this.
  3. ChapmanF
    15,622
    C1241 indicates an abnormal voltage measured at the brake ECU. Despite the temptation to jump from "voltage" to "12 volt battery", one has to remember this code is about voltage reaching the brake ECU, and the troubleshooting instructions give a lot more attention to the wiring and connections in that circuit than to the battery.
    C1310 is a code set in the brake ECU when it knows the hybrid-vehicle ECU is reporting some problem. If you are not seeing another code from the HV ECU explaining what that problem is, chances are you are using a code reader that can't read all the codes in a Prius. Arranging for the codes to be read with a laptop running Techstream should reveal the rest of the information you're not seeing, and help lead to a solution.
    Here is information on finding the Repair Manual, if you haven't already.
  4. exstudent
    exstudent Senior Member
    2,213
    901
    Torrance, CA
    Techstream is the OFFICIAL diagnostic and maintenance software made for Toyota/Lexus, and used at Toyota/Lexus dealerships. Bluetooth OBD2 readers and all the various apps for smartphones/tablets are junk: LIMITED code reading ability (can't read ALL codes) and can NOT do any maintenance (bleed brakes, engine compression check, activate CHRS pump, etc). Why waste money on a toy that limits what you can read and can't do maintenance?
    "But I don't DIY." Getting the codes read at a Toyota dealership will set you back $100+. The cost of the hacked Techstream from Amazon will pay for itself.
    Get mini VCI w/ Techstream from Amazon ($18+). Doesn't matter who you buy from, as the cables likely come from the same one or two suppliers from panda land. May have to return/buy a few, as some cables have problems (bent pin-easy DIY fix, to dead cable). Installation easiest on a Windows 32bit OS (XP, Vista, 7). Ask friends/family if they know someone in IT, as this person will likely have obsolete laptops laying around, and might be able to donate for free. B/C the software is hacked, recommended to install on a spare laptop; do not use this laptop for sensitive information (log in & passwords: email, bill payments, etc). This laptop is now your Toyota/Lexus diagnostic laptop. Mac install possible, you just need to search online.
    Should you stop driving a Toyota/Lexus, you can easily sell your Techstream laptop set-up here.
    Private Sales | PriusChat
    Skibob likes this.
  5. John trapp
    Hyannis
    Replaced 12v and all is good thanks
  6. bisco
    49,500
    well done!(y)
