Death Triangle
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gordonmcds, Jul 21, 2017.
  1. gordonmcds
    gordonmcds New Member
    Auburn, WA
    About two months ago, my drive battery finally died. I replaced it, after a mere 315000 miles. Everything was going fine until this morning. When I was coasting down a hill, I engaged the brake assist (B) on the shifter. Shortly after the triangle showed up. I switched it back to "D" and it went away. Stopped at the local O'Reilly and borrowed their code scanner. The only code was the Catalytic converter code which I already knew about and haven't done anything about it. It happened once more when I hit the brakes fairly hard but it went away just as quickly as it showed up. Is it the inverter? The brake master cylinder? I'm at a loss. I don't want to toss the car as it has been very good to me, however, I also don't want to dump a lot of money into this old of a hybrid. If it were a 69 Chevelle, that's another story. Any advice would be greatly appreciated.
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,371
    3,222
    Madison, Wisconsin
    Sounds like you need a scanner that can extract whatever codes your car is throwing.
    If the triangle came on there is something in history. You may need to go to a dealer or independent shop that has the correct equipment. Or buy it yourself.
    Or just wait for it to get worse.
    Could be several things. Really just throwing darts at this point.
    - Battery can't accept the regen?
    - Brake system issue?
    You won't know without more data.
    Raytheeagle likes this.
  3. jerrymildred
    jerrymildred Senior Member
    11,513
    14,118
    Tampa, FL
    +1 to @ericbecky's comments. Without the codes, it's a million to one guessing game. O'Reillys and such places generally can't read the hybrid codes.
    Also, You should probably click the "Report" button and ask a moderator to move this to the Gen 2 Care, Maintenance, and Troubleshooting forum since your 2005 is a Gen 2 Prius. You'll get more focused attention that way by other Gen 2 owners.
  4. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    With what?
    Agreed, need the codes read by a scanner that can see all of them.
  5. bisco
    49,507
    agree with 'with what?' if it's a new toyota battery look elsewhere. if it's a refurb, likely the problem.
  6. stylinnnn
    stylinnnn Junior Member
    36
    san diego
    yes get refurb batteries and you will be good
  7. ericbecky
    4,371
    3,222
    Madison, Wisconsin
    Refurb...hmmm.
    That could mean so many things. There isn't and standard for terminology.
    So easy to get scammed.
    Module swap.
    Balance. Or not.
    Charge discharge. Or not.
    New buss bars. Or not.
    Clean buss bars. Or not.
    Nationwide part warranty. Or not.
    Recent cells. Or not.
    Etc, etc, etc
    For now NEW is best for longevity.
    Most other options will be a crapshoot.
    And you'd really need to delve deep to understand what you are getting.
    At that kind of miles it will be a hard choice.
    Raytheeagle and jerrymildred like this.
  8. jerrymildred
    11,513
    14,118
    Tampa, FL
    OP, in this case, stand both for "original poster" and "only post." And it was almost a year ago. I wonder what he did with the advice.
