Dec 2019 Electric Bill
Discussion in 'Prime Plug-in Charging' started by Marine Ray, Jan 26, 2020.
  1. Marine Ray
    Marine Ray Senior Member
    1,139
    947
    Sparks, NV
    FYI. Here's my Dec 2019 electric bill. YRMV. Live in Northern Nevada, Reno. On time of use plan with NVEnergy. 1500 sqft house. No solar. Two adults. Gas heat and water heater. Electric stove and dryer. Hang laundry out to dry. Indoor temp 69F during day and 65F at night. Please note $15.25/month service fee regardless if I use 0 kWh or a million kWh. Time of use for entire house usage. PP charge overnight exclusively. So for Dec 2019 about 200 kWh for PP at $10-11/month. That's consistent with the past 11 months.
    #1 Marine Ray, Jan 26, 2020
  2. john1701a
    john1701a Prius Guru
    12,840
    5,311
    58
    How does "winter" billing differentiate from the warmer months?
    Living in Minnesota where the seasons are rather obvious, I honestly don't know how energy demand seasonally fluctuates for your region of the country.
  3. Marine Ray
    1,139
    947
    Sparks, NV
    52,521
    we just got an offer for 22.5 cents/kwh for a 3 year contract vs 24 cents now.
  5. Marine Ray
    1,139
    947
    Sparks, NV
    Do you have a recurring monthly service fee like I do ($15.25) or just 24 cents per kWh?
  6. Salamander_King
    Salamander_King Senior Member
    11,024
    8,972
    New England
    Compared to yours, our monthly consumption is 3 times of yours @ 2 times more expensive electric rate /kWh.:cry::cry::cry:
  7. Marine Ray
    1,139
    947
    Sparks, NV
    Don't despair. I may have higher costs in other areas :)
    Salamander_King likes this.
  8. bisco
    52,521
    straight cost, no monthly minimum. although, i have no idea if the cost would actually be zero if we shut the place down. they would probably come up with some charge or other.
    Marine Ray likes this.
  9. DeaK
    DeaK New Member
    New York
    2020 Prius Prime
    There is a Service Connection Fee to have access. On Long Island we pay .21 per kwh so at the 25 miles per 8.8 kwh battery charge we pay 8.8 x .21 = 1.85 for a full charge to go 25 rated miles = 1.85 / 25 = .074 per mile. Gas at $2.75 gal / 52 mpg = .05 per mile.
    However a full charge rated at 25 miles shows 29 on the display after a full charge and is 35 miles in practice with regeneration
    Thus, 1.85 / 35 = .05 per mile on electric.
    Charge Mode is great when gas is cheaper than electric or when you want a charge for stop and go traffic.
    Driving a constant 30-40 mph in HV mode will recharge your battery and move you forward. Still looking for this sweet spot.
    Old Bear and bisco like this.
  10. Salamander_King
    11,024
    8,972
    New England
    Just FYI, the full charge is not 8.9kWh, Even though that is the spec of the full capacity of the battery, most EV (including the Toyota hybrid) let you charge only up to ~85% and let you drain down to ~15%. For PRIME it comes out to be ~6.5 kWh for a full charge using L1 EVSE, and slightly less 6.1-6.3kWh using L2.
    You are correct in that you can get more than 25 miles of EV most of the time, but that really depends on how and where you drive and temperature/weather. During summertime, I can get up 35 miles on my hilly terrain commute, but in winter sometimes it is less than 20 miles. Incidentally, my electric rate is very close to yours at $0.205/kWh, but gas is cheaper at $2.30/gal now. Gas mileage is also affected by the same variables so that in summer I can get above 65mpg easily but in winter sometimes dips down to 40mpg. On average 25miles EV range and 53mpg as reported by EPA standard for the PRIME is very close to my real average. On average, my HV comes out to be just about even with EV in terms of cost per mile at $0.55/miles.
  11. Sideshow Bob
    Sideshow Bob New Member
    Prince Edward Island
    Our utility would bill us a $25 a month system maintenance or service fee even if we used no power.
