Decent Replace 1.8L Pistons and Rings Video - Engine Out
Discussion in 'Prius v Main Forum' started by rjparker, Dec 30, 2024.
  1. rjparker
    rjparker Tu Humilde Sirviente
    9,483
    5,804
    Texas Hill Country
    Well done engine out video to replace 2010-14 low tension rings and pistons with revised parts. Engine had 181k miles.
    He reports it went from 1 quart every 1,500 miles to 1/4 quart every 9,000 miles. $600 in parts. Kit in TSB-0169-16
    Includes good assembly tips and clear video for a head gasket and timing chain job.
    Reinstalling engine
    Bonus Video by this Channel:
    Brake bleed after Brake Booster Replacement with $59
    TOPDON TopScan OBD2 Bidirectional Scanner (requires $50 year subscription after first year)
    #1 rjparker, Dec 30, 2024
  2. Mendel Leisk
    40,452
    in part 2, around 7:20 he mentions the head bolt driver as being "a triple square". While that seems to work, it's not optimum; Toyota specs a 10 mm double-hex, which is readily available.
    like the occasional "subliminal" bits. :)
    Should this be in gen 3 maintenance sub-forum?
    #2 Mendel Leisk, Dec 31, 2024
