Deciding between 2010 2 or a 2013 c 1
Discussion in 'Gen 3 Prius Main Forum' started by weirdstar, May 23, 2021.
  1. weirdstar
    weirdstar New Member
    Hi there!
    Would anyone be able to help me decide between these two? I'm currently car-less and will have to return to work soon. LA gas prices are no joke, but only older Priuses are in my budget since the used car market is insane right now.
    Both in California.
    2010 II - $8885
    -odometer reads 237,000 but a 2015 engine was put in and the new engine has 48,700 miles on it
    -hybrid battery replaced 1 year ago
    -new tires
    -spent its first year in Maryland as a rental car, but other than that, owned by one owner in CA and well maintained.
    I'm thinking the only major thing left to go wrong with this one is transmission. I know it's rare, but since the car has been driver for over 200k miles, I'm guessing it's only a matter of time?
    2013c I - $8600
    -97,109 mi
    -as far as I know, nothing major has been replaced on it
    -2 owners, CA
    -would be crazy cheap for insurance!
    About to go check out the latter now. Is a PPI always recommended? And I'm assuming ideally from a Toyota dealership or specialist?
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,457
    6,560
    Texas Hill Country
    I might go with the 2010 from an engine miles standpoint and just because its a nicer car but these models also have expensive brake pump and master cylinder design flaws that cost over $2k to fix. The transaxle is not a concern. The 2015 engine still has a poor egr and intake manifold design which require expensive cleanouts if you are not an advanced diy'er. Finally most hv battery replacements are with used packs that don't get the nine to twelve year runtimes of the original new oem. If you buy this car verify through Toyota the hv battery was new.
    Because of those concerns I would go with the 2013 c. Much simpler 1.5L engine. I would have it checked in any case by a hybrid experienced shop.
    Montgomery, mikey_t and Tim Jones like this.
    52,351
    agree, go with the 2010 if you can confirm the engine, and if the battery is oem toyota.
    a lot of scammers out there.
    that price seems awfully high, but cali i guess?
    Montgomery and mikey_t like this.
  4. Grit
    Grit Senior Member
    6,576
    4,228
    Wilkes Land
    commiefornia is preferred.
  5. ETC(SS)
    7,332
    If you don't mind the size?
    The Priussy.
    (Prius C)
    More dependable.
    Half the miles on everything but the motor.
    Still under CARB warranty in the PRC for 2 more years.
    NOT a rental car per the OP.
    No Brainer!
    mikey_t likes this.
  6. mikey_t
    mikey_t Active Member
    371
    391
    Los Angeles
    I've read that there's a shortage of used cars everywhere right now so prices are inflated. Might be a great time to trade in or sell if one was thinking about it.
    #6 mikey_t, May 24, 2021
    Montgomery and bisco like this.
  7. bisco
    52,351
    i have read that too. that's what makes a new prime so appealing, plentiful and cheap
    mikey_t likes this.
  8. Grit
    Grit Senior Member
    6,576
    4,228
    Wilkes Land
    im gonna sell mine and get a model 2, forget driving mine to the ground anymore.
  9. weirdstar
    Thanks so much everyone! I think I am going for the C. And yes, used car prices are absolutely insane. These are some of the more reasonably priced things I've found. Unfortunately, I've been working remotely and am about to have to return to the office and don't currently have a car already. Fantastic timing, haha.
    Thanks again for all your input.
    mikey_t likes this.
