Decrease in gas mileage on 2010 prius
Discussion in 'Gen 3 Prius Fuel Economy' started by rjp123, Sep 19, 2013.
  1. rjp123
    rjp123 Member
    112
    63
    I have notice decreased gas mileage on my 2010 Prius and I am wondering if this is just normal age related wearing out of either the ICE or hybrid system or if there is something I can do about it. Here are some facts. Thanks for any help.
    I drive the exact same route to and from work every day. It is approximately 50 miles (mostly hwy) each way. I have been doing this since the car had 4K miles on it and it now has about 70K. (2.5 years)
    All mileage figures quoted are from the onboard display, which I reset every trip.
    For about the first 36000 miles I reliably got warm-weather mileage of about 57 mpg to work, and 50 returning (probably due to elevation difference or wind I assume?)
    Since then the warm-weather mileage dropped to about 48 to work and 42 returning. Approximately a 8 mpg drop in fuel economy. It's like I'm now getting Winter mileage all Summer now.
    To my knowledge, nothing has changed that could account for this.
    I replaced the tires at around 50K miles with the OEM brand, but there was no change in mpg.
    Same 0w20 synthetic oil every change, good tire pressure, air cleaner replaced, engine top end cleaned recently. No improvement in mileage.
    What could be causing this?
  2. bwilson4web
    15,528
    An 8 MPG drop is roughly a 16% drop in efficiency. Let me suggest looking around for a loop or flat, 10 mile stretch to see how your MPG compares to this benchmark:
    Use cruise control to manage the speed and reset the trip meter once in cruise mode:
    • slow speed 30-40 mph
    • high speed 65-75 mph
    The second thing is to get some metrics from the car in operation:
    • miniVCI - a way to survey what is going on in the car and read out any 'stealth' codes
    • Scangauge II - you'll need to add some XGAUGEs to find the interesting metrics
    It is a lot of fun to list what might be broken but more useful to get some metric and diagnose what is going on.
    rjp123 likes this.
  3. rjp123
    rjp123 Member
    112
    63
    Bob, thanks for the reply. I am not sure why it would be useful to compare my mpg to the above benchmark since in my case I have the benefit of established driving history over the exact same trip every weekday for 2.5 years.
    I am definitely interested in getting the metrics you mentioned. Should I go to the dealer and ask for this scan or is this something I can do at home with the purchase of some data interface device perhaps for a PC? I have such a device for reading OBD-II info but that is all.
    Are there any self tests using the dash indicator like on the Gen 2 cars for battery condition?
  4. bwilson4web
    15,528
    My benchmark data should be reproducible by any car using a reasonably flat, 10 mile course, averaging the running MPG at the same speed, both directions. I appreciate you have a 'route' but I have no idea what that route consists of. Worse, I may not be able to reproduce a similar track. However, most of the country have a reasonably flat, 10 mile stretch along rivers or near large bodies of water or industrial parks on the weekend.
    Terrain and distance are great 'unknowns' so I've tried to use what can be found.
    The more recent versions of miniVCI work with out 2010 Prius and can record some data. Also, "Frank" has been doing some excellent work with an Android and data collection.
    None that apply to your problem.
  5. bisco
    49,514
    you may have a weak 12 volt battery. i'm in the fun business.:)
  6. rjp123
    rjp123 Member
    112
    63
    I doubt it, but I will look into it. The reason I don't think it is the 12v is because the care starts easily and after idling for about only a minute the engine shits off which makes me think the battery is full charged (Just guessing here, but wouldn't it keep running if it was needing charge?), which makes me think it must have held its charge overnight pretty well. Can I simply test it with a volt meter?
  7. rjp123
    rjp123 Member
    112
    63
    How long do the high voltage batteries last on these? I assume that as they age they can hold less and less charge and so the ICE will be required to run a greater percentage of the time. I wish Toyota provided more data on the electrical drive system than just the little picture on the dash. I think many technically minder owners would appreciate basic parameters like instantaneous current flow, voltage, battery charge cycles, total energy use per trip, etc, with real numbers rather than little stacks of cars.
  8. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    the hv battery is warrantied for 100/150k miles depending on state. it is possible you might have a bad cell.
    thgim uim ui
  9. rjp123
    rjp123 Member
    112
    63
    Yes, but what exactly is the HV battery warranted to do for this period? Are the conditions of that warranty spelled out somewhere? I would like to read up on it. I am guessing since all batteries weaken over time it may only be warranted against failure. To cover weakened batteries they would need to specify some level of minimum energy capacity below which it is considered unacceptable. Have you heard of any such thing?
  10. JimboPalmer
    12,470
    6,866
    Greenwood MS USA
    a) The 12 volt battery boots the computers, but the HV Battery starts the engine.
    b) the engine charges the HV Battery, but the HV Battery charges the 12 volt battery. So the engine never 'sees' the charge of the 12 volt battery.
    c)Yes you can test at the battery in the back, or at the Jump point in front, or both.
    rjp123 likes this.
  11. xliderider
    xliderider Senior Member
    7,873
    3,116
    Honolulu, HI
    The engine running and shutting off is related to the SOC of the HV battery not the 12v battery.
    You should measure the voltage of the 12v battery at the terminals and report back here. Should be about 12.4v
    rjp123 likes this.
  12. rjp123
    rjp123 Member
    112
    63
    This is great information guys. Thanks! I had no idea the HV battery started the car and was responsible for charging the 12v. I will go and measure the 12v voltage now and report back.
  13. JimboPalmer
    12,470
    6,866
    Greenwood MS USA
    a) the car will not start without the HV Battery, so failure is the only warranty.
    b) of course it is. http://www.toyota.com/t3Portal/document/omms/T-MMS-10Prius/pdf/2010_Prius_WMG_0W20_lr.pdf
    c) Your warranty is digital, it works or it doesn't. And there is no pro-rating, they replace it or they don't.
  14. rjp123
    rjp123 Member
    112
    63
    I just measured the 12v battery. After sitting overnight the voltage was 12.6.
    After pressing the start button twice (accessory mode) it was 12.3, and after pressing start with foot on brake (run mode) it dropped t0 11.9 for a split second and then went up to 14.3.
  15. rjp123
    rjp123 Member
    112
    63
    Thanks. I already read that warranty document when I bought my car. It has no specifics about what qualifies as a good or bad battery. I suspect you are right about (c) though. If that is the case it is fairly useless coverage and only protects against catastrophic failures.
  16. bisco
    49,514
    it's not 'normal wear and tear' on the hv battery or ice. mpg's don't decrease much with age unless there is a problem. a bad cell in the battery will throw a code. you can buy a scangauge and read a lot of info about the systems. read up on it in some of the threads here. there are some people measuring the health of thier battery with a device that hooks up to the obd port.
  17. JimboPalmer
    12,470
    6,866
    Greenwood MS USA
    We have years of PriusChat right here, what other failures have you found?
  18. rjp123
    rjp123 Member
    112
    63
    Thanks. That is the sort of info I was trying to find out. I was wondering if my drop in mileage was due to wear and the first thing that came to mind was the HV battery. I have no basis for this at all other than my experience with other devices that use rechargeable batteries. The batteries always seem to be the weakest link. I have a friend who is a tech at my local Toyota. I am going to ask him if he can hook up some expensive test equipment and tell me about the condition of my battery. Surely they must have a battery health metric in there somewhere. I did mention the mileage drop to him last time I was in and that's when he changed the air filter. Made no difference though.
    Any suggestion of exactly what I should ask him to look for? Or should I just say mileage has dropped and leave it up to them to check? I just got the feeling they didn't take it very seriously last time. I really love the car and would like to get my old fuel economy back if possible.
  19. bisco
    49,514
    dealers are ill equiped to do anything but hook up the computer and see if the car has any information for them. (fault codes) if it doesn't, they revert back to old fashioned techniques, i.e. change the air filter. the hv battery is made up of many individual cells. when one or more drop below a given parameter, it generates a code. at that point, the dealer will tell you you need a new battery, either under warranty or at your expense. until that day, the best thing you can do is study the low mileage threads and start looking for possible things that can be repaired or cleaned or adjusted on your car. there are at least a dozen or two common things that should be looked into such as tyre pressure and air filter to throttle body cleaning and over filled engine oil.
    rjp123 likes this.
  20. rjp123
    rjp123 Member
    112
    63
    Thanks. I guess my plan, then, is to go to the dealer and have them pull the codes at the next oil change.
    I have already checked tire pressure, changed air filter, and had a treatment done to clean throttle body/top end.
    I am ready to start searching deeper through the forums for answers. My primary reason is starting this thread was to first find out if this gradual drop in fuel economy was normal and something everyone was experiencing. In my initial searches so far I didn't find any other threads describing dropping mpg over time, and I would imagine that if this was indeed happening people would be up in arms about it and it would be all over the net.
    Thanks for all the input so far. Any pointers to important threads you guys can think off would be appreciated (also any important questions to ask at the dealer's to help guide them to the problem).
