Decrease in MPG as car ages?
Discussion in 'Gen 2 Prius Main Forum' started by Kablooie, Jun 6, 2010.
  1. Kablooie
    Kablooie Member
    273
    La Canada
    My 2004 Prius has 102000 miles and it seems to be getting less MPG. I used to average around 43 and now I'm getting 38 or 39 MPG most of the time.
    Has anyone else experienced this? I'm wondering if the battery loses charge capacity as it ages.
  2. macmaster05
    macmaster05 Senor Member
    4,050
    730
    whoa. Please advise.
  3. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    Some people have reported that a failing starter battery (not the traction battery) has this effect. Does your Prius have the original battery?
  4. Kablooie
    Kablooie Member
    273
    La Canada
    Yes. I don't think I've changed the starter battery. It's been 6 years so I'll try replacing it and see if that helps.
  5. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    If anything, my '04 is getting *better* MPG at 130K, esp. as this
    summer kicks in and on the new Michelin EnergySaver a/s tires.
    Finished a run to the Cape and back just today, showing just
    over 70 MPG and much of that was highway at 60+ mph. Traction
    pack is fine, as recently checked, and its 12V is still the
    yellowtop from elearnaid which I don't expect to poop out
    for a good couple more years.
    _H*
  6. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Before you replace the battery check the voltage & report the readings. For the record, I expect your 6 year old battery to be weak but KNOW why you're swapping out a part, don't GUESS or HOPE that will solve your problem.
  7. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    What tires do you have now (size, make and model please) and what pressures do you keep them at? Perhaps you've changed them to something w/higher rolling resistance?
    Yes, the HV battery does lose capacity over time but government long term tests didn't show significant mileage changes, at least not on Gen Is. See http://priuschat.com/forums/gen-ii-...-miles-w-dropping-mpg-common.html#post1014257.
  8. bisco
    52,404
    that's excellent H! any tips? we usually get low 60's on the way down and high 50's on the way back. factory tires and 55-65 mph. mostly 65. thanks!
  9. Kablooie
    Kablooie Member
    273
    La Canada
    Good point. I checked and it's 12.5 V cold and 13.75 when idling.
    So the battery seems to still be fairly good. Hmm.
    About a month ago I got new Michelin Energy Saver A/S P185/65R15 all at 35 psi.
    I was getting about this mileage with my previous tires and assumed they could be the problem. When the sidewall of one of them ripped I decided to replace the tires with new energy savers. If anything, the mileage is a little less than before.
  10. a_gray_prius
    2,927
    783
    IL
    When is the last time you checked your alignment?
  11. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    The new tires must "break in" before they will yield good mileage.
    It's time for the spark plugs to be checked/replaced.
    Engine air filter ok?
    The Prius is good at not aging fast, but even it requires maintenance eventually. ;)
  12. hobbit
    4,089
    469
    Bahstahn
    Very late answer to bisco and anyone else curious: This may help,
    as I hadn't finished writing it at the time the topic came up...
    _H*
  13. LoveMyPriusIII
    LoveMyPriusIII New Member
    66
    12.5 seems pretty low. I think it is supposed to be 12.8.
  14. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
  15. NoMoShocks
    NoMoShocks Electrical Engineer
    1,292
    83
    Camas, WA
    I think you need to turn on the headlights and see it that 12.5 V imediately drops below 12 V. I new fully charged battery would be closer to 13.2 V with the car off.
