Deep grooves on upper part of rotor
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mololo, Jun 7, 2023.
  1. Mololo
    Mololo New Member
    Hello,
    I have a 2011 with 83k. Recently I started hearing a grinding noise when braking at 5mph or less from the left rear wheel. And discovered these deep grooves.
    What do you think caused it? How serious is it?
    Will I need to disconnect the 12v to check if there's something stuck between pad and rotor? 4C044846-C499-4FF8-8C56-8A26E4B7BDFF.jpeg
    thanks
  2. taxidriver50005
    taxidriver50005 Active Member
    204
    170
    GB
    Excel
    If its not a stone it could be pad material has dislodged from backing plate... Or just worn out
  3. taxidriver50005
    204
    170
    GB
    Excel
    Shouldn't need to disconnect battery but move keys to back of house as not to activate brake servo pump.
  4. taxidriver50005
    204
    170
    GB
    Excel
    After looking again your going to need pads.. That looks worn out.
  5. xliderider
    xliderider Senior Member
    8,056
    3,223
    Honolulu, HI
    83K miles? Our 2011 Prius hatchback with over 130K is still on the original brake pads, though most of the miles were highway/freeway miles.
  6. ASRDogman
    ASRDogman Senior Member
    7,243
    3,780
    Pull the wheel and you'll probably see there is no pad material left.
    And the top of the pad is metal on metal.
    You'll needs pads at the very least, but rotors should also be replaced.
    You'll need the tool to rotate the caliper puck back into the housing.
    You can rent it from autozone or other auto parts place.
    You do not have to disconnect the 12v battery. Just do NOT open the drivers door.
    And might be a good idea to keep the key fobs at least 30+ feet away from the car.
  7. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    Brakes must ve been draggin for the longest time with 20 mpgs average!
  8. Mendel Leisk
    40,584
    Did you have the rear brakes serviced not too long back? If the caliper pistons aren’t rotated just right, and well seated thus, they’ll cause grossly uneven pressure application to the pad back, beveled pad wear, area of the rotor not making contact with pad, symptoms like that.
    there’s a link in my signature on rear brake drag; if on a phone turn it to landscape to see signature.
    xliderider likes this.
  9. Mololo
    Mololo New Member
    The previous owner was a family member who isn't the most graceful driver to say the least haha
    No, I don't think there was any work done it. I'm not the original owner. Thanks for the links.
    thanks for your tips
    thanks
    #9 Mololo, Jun 7, 2023
  10. Mololo
    Mololo New Member
    Update: the caliper had seized. I need to replace pads, rotors and calipers.
  11. ASRDogman
    7,243
    3,780
    Had you ever flush the brake fluid?
    Or cleaned the glide pins?
  12. Mendel Leisk
    40,584
    Where in the States are you, more specifically? Is there road salt usage?
