Deer and cables under the car mystery
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by gafortiby, Sep 6, 2016.
  1. gafortiby
    gafortiby Member
    74
    45
    Colorado
    I just purchased a used 2012 prius v with 25k miles. I got a hold of some old maintenance records through Toyota owners portal, and it has this service from 2013.
    05/23/2013, 6500 miles
    CHECK AND ADVISE ON UNDERNEATH DAMAGE AFTER RAN OVER DEER
    WOULD NEED TO REPLACE CABLES, EST $840 LABOR,$863 PARTS
    Whatever this is, I am sure it is fixed since the car is fine and has passed multiple inspections since then. But I am curious... What could this be? $840 in labor would be something like 7 hours of labor assuming the typical $120/hr dealer rate. What cable/cables under the car would cost $863 in parts and take 7 hours to replace? Maybe the main traction wires (the thick orange ones)? or perhaps "cable" means brake cables?
    I have not gotten under the car yet but it drives perfect with no issues.
    49,508
    good question. not sure if the high voltage cables are part of the wiring harness, but that is more like $6-8,000. so maybe not.
  3. RAM v
    RAM v Junior Member
    72
    St. Paul, MN
    2014 Prius v wagon
    Parking brake cables to rear wheels maybe???
  4. Mendel Leisk
    38,736
    That's your best bet, look for obvious signs, new/clean components, any scuffs, dangling/missing plastic shields, holes with no fasteners.
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    ...new/clean components, any scuffs, dangling/missing plastic shields, holes with no fasteners....antlers....
  6. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    Fur... Found red fox fur wedged into the Porsche splitter after the unfortunate critter tried (too late) to dart in front...
    #6 Air_Boss, Sep 8, 2016
  7. gafortiby
    gafortiby Member
    74
    45
    Colorado
    Mystery solved! Here is the broken part under the car.
    It does look like the main traction battery cable, and the white bracket that holds the cable is broken in several places. It looks like it was zip-tied a long time ago. This is the area just ahead of the rear wheels, under the floorboard of the rear passenger seat.
    The selling dealer has ordered this white plastic bracket from Toyota, however we are very unsure whether we got the right part numbers. $50 in parts. We'll see how easy it is to replace it once they get the part. It comes as top and bottom separately from Toyota so it looks like a simple replacement.
    #7 gafortiby, Sep 12, 2016
  8. bisco
    49,508
    is it the high voltage cable?
  9. Mendel Leisk
    38,736
    Orange cables are the High Voltage, yes.
  10. gafortiby
    gafortiby Member
    74
    45
    Colorado
    Well I've searched high and low and can't get the part numbers for this white bracket. I'm convinced that Toyota does not sell it separately and we just ordered the wrong part. The entire cable assembly is about $500 on discount and I don't think I will go that route.
    I may have to buy a used cable off eBay just to grab that bracket. Or rig something up to keep it better secured than a single zip tie.
  11. bisco
    49,508
    ouch. is that a valid fix?
  12. Air_Boss
    3,952
    1,083
    New Yawk
    $800 dollars of protective milk crate plastic with $800 of labor?
    Raytheeagle and bisco like this.
  13. gafortiby
    gafortiby Member
    74
    45
    Colorado
    Haha. No I think that original quote from 2013 is the cost to replace the entire cable assembly, since I don't think Toyota sells that plastic bracket separately. To replace the harness, I think you have to take out the hybrid battery and quite a few things on top or bottom of engine bay.
    I'm definitely not doing that.
  14. Air_Boss
    3,952
    1,083
    New Yawk
    How many miles and years does it have on the tie-wraps?
  15. gafortiby
    gafortiby Member
    74
    45
    Colorado
    re: tie wraps
    It has been tied like that for about 3 years and 15k miles. That is my best guess based on old maintenance records.
  16. Mendel Leisk
    38,736
    Are you missing this whole panel, maybe both sides?
  17. gafortiby
    gafortiby Member
    74
    45
    Colorado
    WHAT i definitely don't have those panels. However maybe the v doesn't have them, is yours a regular Prius?
  18. Mendel Leisk
    38,736
    Ah woops, not paying attention. I was actually taking a look under our (regular third gen), looking for comparison, lol. Not sure about the v. Hopefully someone with the right vehicle can take a look, chime in.
  19. gafortiby
    gafortiby Member
    74
    45
    Colorado
    Not sure. There are some good pictures of the undercarriage of the v in this thread, and I don't see any undercarriage covers on that.
    Granted it is a modding thread so not sure if this is stock appearance.
    My Tanabe R&D Experience (long) | PriusChat
  20. Mendel Leisk
    38,736
