default nav screen
Discussion in 'Gen 2 Prius Audio and Electronics' started by wesj49, Jan 4, 2004.
  1. wesj49
    wesj49 Junior Member
    72
    CA Central Coast
    Is there a way to set the default screen on the nav system. I would like to be able to stay on the Audio screen because I mix cds and study these their music while driving. In other words, with cd text I can see which track easily and move back and forth through songs to specific points in the music by the playing time...but the screen defaults back to the map or consumption screen. Does this make sense? Maybe the question really is How to get the screen not to return to the consumption or map screen automatically?
  2. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    Check the manual or the setup screen for the feature that automatically returns to map. I believe that would be Info (not the wheel, but the screen trim button), then Screen Setting. Then try changing the Transition setting (default is on).
    hope this helps,
    -Rick
