Defect on Fog Lights
Discussion in 'Prius c Technical Discussion' started by eco31, Aug 7, 2012.
  1. eco31
    eco31 Member
    213
    57
    IE
    Has anyone taken a look at their fog lights? The fog light on my C4 looks like it has been burnt. I will post picture later today. I didn't notice it until I was trying to install my fod light. I haven't put in any other bulbs in there besides what came from factory. The HID bulbs were never installed in the housing. Please take a look and let me know.
    Thanks!
  2. DKTVAV
    DKTVAV Active Member
    510
    101
    What do you mean by burnt? I'll go out to the parking lot to take a look, but need to know what I need to check first.
  3. eco31
    eco31 Member
    213
    57
    IE
    Here are the photo.
  4. Oldwolf
    Oldwolf Prius Enthusiast
    816
    107
    NC
    2016 Prius v wagon
    You are correct. Your reflector looks like it has overheated.
  5. deckbuild
    deckbuild Junior Member
    42
    Singapore
    What wattage are those bulbs in your fog lamp?
  6. Oldwolf
    816
    107
    NC
    2016 Prius v wagon
    For OEM they are H16 halogen bulbs rated at 19 watts.
  7. DKTVAV
    510
    101
    Oh no, I thought I've read it somewhere it's the same as low beam headlights H11. I've ordered another HID set H11 to use with these fog lights, now I'm screwed.
  8. Oldwolf
    816
    107
    NC
    2016 Prius v wagon
    FYI I got that info out of the owners manual.
  9. DKTVAV
    510
    101
  10. eco31
    eco31 Member
    213
    57
    IE
    The fog light bulb from the factory says H16 but the replacement one I got to replace the factory one says H11. H11 will work for you fog light. I have H11 in 3000K for my fog lights. The Toyota rep said that it probably didn't have proper ventilation so it burned the housing.
  11. Oldwolf
    816
    107
    NC
    2016 Prius v wagon
    Are you saying the fog lights burned the reflector using the factory installed bulbs?
  12. eco31
    eco31 Member
    213
    57
    IE
  13. Oldwolf
    816
    107
    NC
    2016 Prius v wagon
    Well then, I will start using mine to see if i get the same result.
  14. SILVERCwSUN
    SILVERCwSUN Member
    261
    77
    29
    Western North Carolina foothills
    I will hold off on this optional install...thanks for the update.
  15. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    thats a bad design if normal bulbs will cause the housing to get messed up.
  16. Oldwolf
    816
    107
    NC
    2016 Prius v wagon
    I haven't had a problem with mine.
  17. Ryan Case
    Ryan Case Junior Member
    38
    Normal, IL
    Another reason to use LED's vs. Halogen bulbs in my mind. The temperature inside the housing "should" be lower at the same lumen output.
  18. kingnba6
    1,018
    242
    NY
    but you will not be able to get the same output as halogens when you put leds in the same housing. to actually make leds work on the same level as halogens, you will need to replace the whole housing with a proper led housing,
  19. B2FiNiTY
    B2FiNiTY Active Member
    979
    226
    Anybody having issues with this? Worried that using a H11 will burn out the housing due to heat...
  20. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    I run mine for 2 hours a day 5 days a week. I have had this for 3 months now and haven't had a single problem with the H11 HID bulbs in the fog sockets.
