Definitive First Gen Cruise Control Install
Discussion in 'Generation 1 Prius Discussion' started by AJ7, Jan 14, 2022.
  1. AJ7
    AJ7 Junior Member
    San Diego
    2002 Prius
    I
    I had a really hard time finding info on adding Cruise Control to my 2002 First Gen Prius-
    Lots of conflicting info and nonsense- But it turned out to be very simple- so hopefully this helps someone.
    ((I have heard 2001 cars might be different? but unsure))
    Part No.
    08501-47801
    Comes with a brand-new steering wheel with the cruise switch installed AND the correct brake pedal switch. I was able to order for about $150.
    Order from any Toyota dealer and they should be able to get it shipped in for you in a few days.
    I got a better price buying it from the dealer website than they would do at the counter for some reason.
    Online it will only show a picture of the switch by itself- saw a bunch of writeups on chopping up the steering wheel- but there is no need to.
    I even called the dealer and asked what it came with- they told me it would only come with the switch- ordered anyway and it came with everything needed.
    Cars without cruise control have a brake pedal switch with only two contacts- for cruise control the switch has 4. Needed to tell computer to cancel cruise.
    To replace the pedal switch- I read about cutting up wrenches and special tools etc. but none are needed if you unscrew the two fasteners holding the panel under the wheel. Pull it down a few inches- I left all wires connected- gives you room to see and room for an open end 14mm wrench just to loosen the set nut. Or use a crow foot wrench.
    (Disconnect 12v batt for convenience- I bumped contacts of the switch with the wrench and popped the brake light fuse)
    New brake pedal switch goes in and make sure it clicks as the pedal just comes forward.
    (Check that the brake lights go on and off with slight pedal movement when done.)
    Thread switch in or out to adjust- and lock nut to hold in place.
    Next comes the wheel.
    This involves removing the airbag at your own risk.
    Disconnect HV orange battery disconnect in the trunk- left side of battery pack. (For extra safety)
    Rotate and lift up- I used HV gloves. (For extra extra safety).
    Then disconnect 12v battery- ensure there is no way the terminals can reconnect by mistake.
    Wait at least 90 seconds according to Toyota- or go get a coffee-
    --Start with wheels straight ahead and steering wheel exactly in the middle--
    Remove two captive t30 screws- plastic trim back of the wheel.
    Will release airbag- magnet or slim pliers help pull screws out of hole a bit to free up airbag.
    Pull out gently- and disconnect yellow plug- do not stretch the wires or yank- be more gentle than normal.
    Once out place the airbag (with the toyota label facing up) out of the way.
    19mm socket- remove nut holding steering wheel-
    Use steering wheel puller with two long m8 bolts threaded into the wheel-
    Spiral cable should be centered correctly (wire system that connects to the airbag) if nothing moves-
    However, if it does move- Spin ccw until it stops- then cw 2.5 times- will be clocked correctly for center steering position.
    Center new wheel-
    Torque to 37 ft lbs
    Install airbag- Plug in both the airbag yellow connector and the new white milti-pin connector
    Torque torx screws 6.5 ft lbs
    Reconnect batteries and test it out
    -AJ
      File size:
      158.7 KB
      File size:
      133 KB
      File size:
      86.2 KB
      File size:
      76.5 KB
      File size:
      142.7 KB
      File size:
      142 KB
      File size:
      119.9 KB
      File size:
      126.1 KB
  2. ChapmanF
    15,496
    Nostalgia ... I remember going through that same procedure with my 2001.
    Oddly, I think I did that too. (it was one of my first projects ever on my first Prius.) But this job doesn't put you anywhere near the car's high-voltage wiring, and no need to pull that disconnect for this job; it won't provide any extra safety.
    For what it's worth, to be strictly by the book, any time you touch that orange disconnect, you should have your high-voltage gloves on. I think that's probably one of the more commonly disregarded precautions in all Priusdom, but if you look, officially, it's there.
  3. AlexY
    AlexY Member
    160
    45
    UK
    When I was looking for parts, I've found the prices to be a little... insane, ended up with relay in pedal switch circuit, buttons from calculator with resistors as CC controller switch. Was working for years.
  4. ammdb
    ammdb Active Member
    266
    110
    Indianapolis
    My '01 came with cruise control, thought it was standard on this generation.
  5. ChapmanF
    15,496
    My '01 did not. I went with the accessory kit at the dealer, which (as reported above) included everything needed including an entire new steering wheel (no need to carve the old one to mount the switch). I didn't think the $140 or so for that kit was insane, considering everything that was in it, and the old steering wheel was showing some wear by then, so it was nice having a mint-condition new one.
    ammdb likes this.
  6. AlexY
    AlexY Member
    160
    45
    UK
    I'm in UK and when I was looking for it, only source was from US with price $150 + shipping + duty for steering wheel only. Never tried to ask toyota as I have had bad experience with them when was looking for wheel hub.
  7. Cayson
    Cayson New Member
    Utah
    2001 Prius
    I
    Has anyone put aftermarket speakers or an amp in a Gen 1?
  8. ChapmanF
    15,496
    Not as a way to get cruise control.
  9. Cayson
    Cayson New Member
    Utah
    2001 Prius
    I
    oops I thought I was in a different thread
