Delayed engine engagement coming off electric
Discussion in 'Prime Main Forum (2017-2022)' started by JMalmsteen, Sep 12, 2021.
  1. JMalmsteen
    JMalmsteen I love my Prius!
    287
    266
    Long Island, NY/Lancaster, PA
    We have a Prime with nearly 200k miles. For the first time, the following happened- we were driving on the highway about 60 mph and the car transitioned from electric to gas. At the moment the car transitioned, the engine did not engage the transmission and the car started to slow, even though the power was in the red zone. After 30 seconds, the engine engaged the transmission and we went faster.
    I drive 120 miles per day to commute to work and we use this car for about 1k miles per week. I rely on this car a lot, so I hope something major isn't happening.
    Any idea what could be going on with the car? Thanks!
  2. schja01
    schja01 Senior Member
    1,844
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    Are you current on all maintenance especially engine related?
    JMalmsteen likes this.
  3. Trollbait
    12,680
    Sounds like the system wanted to make sure the engine was warmed up before putting a load on it, and didn't have the energy in the battery to keep the speed up during that time. Kind of hard to say from a one time event that could simply have happened from a rare computer glitch.
    Anything else that seems out of the ordinary, like reduction in efficiency?
    I wouldn't worry unless it happens again.
    Well past due for spark plugs if they haven't been done. Coolant and transmission fluid should have been changed in that time too.
    Not sure how that would relate to the engine making power but it not getting through the transmission. If there is a serious issue, I'd think it lies with M/G1, as that is what makes the transaxle work like a CVT.
  4. ChapmanF
    18,545
    Sounds like the engine wasn't very quick to start. My Gen 1 needed some engine TLC too around the same mileage.
    A Prius with a balky engine can be kind of a pain. A conventional car, if you're cranking the engine and it doesn't catch right away, well, at least you're in your driveway.
    A Prius puts up the READY light and off you go on electric, and then the engine kind of sputters to life eventually, or it doesn't, and drops you on the side of the road five blocks from home. :)
  5. JMalmsteen
    287
    266
    We had the 120k service done with the fluids and spark plugs and synthetic oil every 10k.
    Our 2007 Prius is at 500k and has no issues except burning oil.
    The mpg on the car is normal.
  6. BiomedO1
    BiomedO1 Senior Member
    4,135
    2,169
    SacTown, Ca
    Cranking a car engine on your driveway for 30 sec. is kinda normal; but moving 60 mph down the highway - must've felt like an eternity.
    Have you been able to do an OBD scan for trouble codes? There's probably a P300, intermittent miss or P30x - x = cylinder number misfiling.
    You should be on your second set of spark plugs, your transmission fluid and fuel filter, should've been changed. If those haven't been done start there. Absent trouble codes, ignition coils and intake manifold cleaning would be next. I'm making an assumption that the problem is due to deferred maintenance, rather than something actually broken. I'm also amusing engine -oil and -air filters are being changed on schedule. Everything listed above will cause intermittent issues.
    Get back to us with the trouble codes and we can narrow down the fix further; rather than taking a stab in the dark.
  7. JMalmsteen
    287
    266
    We need to get the oil changed again. I can have Toyota pull the codes and see if anything is going on. We had the 120k maintenance done. I don't know if they changed the fuel filter. I'll call Toyota tomorrow to double check the maintenance we had done.
  8. BiomedO1
    4,135
    2,169
    SacTown, Ca
    So this is dealer maintained; they're usually pretty good at doing basic maintenance work - just don't let them talk you into any expensive fixes for now!
    I have read reports, on very rare occasions the CPU would miss the "hand-off" to the ICE, which will cause a delayed startup. Like what you experienced. Unfortunately software hiccups and glitch are now the norm. Ask the dealer service department if your on the latest software and that you've got all the latest patches installed. This shouldn't cost you anything, since you've been such a loyal customer. That may resolve your issue.
    Good Luck......
  9. JMalmsteen
    287
    266
    Thanks, everyone. It didn't happen today, I hope it was a one off occurrence!
  10. JMalmsteen
    287
    266
    No codes and it hasn't happened again. I'll take it!
    jerrymildred likes this.
