Delayed locks
Discussion in 'Gen 4 Prius Main Forum' started by husami, Dec 27, 2019.
  1. husami
    husami Junior Member
    50
    Cincinnati, Ohio
    I noticed that my door locks have about few seconds delay to lock the doors after pushing the lock button. It used to be instant.
    49,844
    check the 12v health. if that's good, maybe a bad relay?
  3. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,585
    near Brisbane, Australia
    Is this the inside or the outside - or the FOB button?
  4. husami
    50
    Cincinnati, Ohio
    it's the button on the fob.
    How do I check the 12v battery health?
  5. alanclarkeau
    7,044
    7,585
    Is it the same with both FOBs?
    I'd be more inclined to check the FOB Battery.
  6. bisco
    49,844
    put a volt meter on it in the morning before opening the doors. don't bring the fob with you.
  7. husami
    50
    Cincinnati, Ohio
    if its low there would be a warning message?
  8. Leadfoot J. McCoalroller
    7,319
    6,833
    Pennsylvania
    2018 Prius c
    Generally not.
  9. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    unless they finally changed it for Gen4, no warning really.
    bisco has it right, pull your hood release and then check it in the morning,
    dont open drivers door or anything before checking.
    edit: i will say it was about 3 years to the day that I first had to replace my fob"s batts
  10. alanclarkeau
    7,044
    7,585
    If the door sensor opening and closing is working fine - I'd suspect the 12v is fine too. Particularly as everything else is working fine too.
    I'd be checking or changing the FOB Battery first.
  11. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    Could it be one or more locks are stiff ?
    Maybe a little thin (3 in 1) oil in the keyholes and work it with the key a few times, it's worth a try.
    alanclarkeau likes this.
  12. alanclarkeau
    7,044
    7,585
    Possibly - except that it works fine with everything except the FOB - which I think points to the FOB.
    kithmo and dig4dirt like this.
  13. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    Sorry I didn't see anything in his posts that said it worked fine with anything else. :unsure:
  14. alanclarkeau
    7,044
    7,585
    I guess it was my assumption that seeing he said FOB that everything else is OK - I'd asked him.
    But - cars and particularly computers and electronics can be sneaky!!!
