delete air filter message on computer screen
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by dhedges, Jun 21, 2011.
  1. dhedges
    dhedges Junior Member
    Ft Davis, Tx.
    How do I delete the check air filter message from the 2011 Gen 3 computer screen? Any help would be appreciated.
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    How many miles do you have? I would suspect the same routine for removing the oil change message: Trip A, power off, press and hold the Miles/Kilometers button, power on, release when reset is done.
  3. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    I don't have nav. Check your owners manual.
  4. Mendel Leisk
    40,584
    I thought there was only a oil change warning that needed resetting, in normal circumstance. Just maybe there is an issue with the engine filter, say not installed correctly?
  5. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    That is what I thought originally too but I believe that with the nav option they have additional service messages.?
  6. PaJa
    PaJa Senior member
    678
    114
    92
    Czech republic
    If you have a chance to browse DTC codes, pls do it and send the details.
    If not, lets try to open engine air filter box and visually check for any dirt or oil appearance. Try to clean the filter with compressed air.
    You can also try to reset the warning message - cycle the car 3 times (Ready-OFF).
  7. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    If you are seeing it on the Nav screen check page 301 of the Nav manual. You can delete all of the vehicle information out of the Nav system then it won't bug you anymore.
