Delta SOC
Discussion in 'Gen 2 Prius Technical Discussion' started by alexeft, Sep 7, 2014.
  1. alexeft
    alexeft Member
    139
    23
    Greece
    Hi all,
    I have been noticing that my HV battery appears to have a little less capacity (drains a little earlier), but all cells appear very close to one another in terms of voltage and internal resistance. Also, the DeltaSOC is 0% as reported by Techstream through the miniVCI.
    What's your opinion on the state of my battery? What exactly is deltaSOC?
    It's a 2004 Prius at 160k miles.
  2. jdenenberg
    jdenenberg EE Professor
    3,852
    1,845
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Your battery appears to be in good shape.
    DeltaSOC is a measure of the differences in the State Of Charge between module pairs. Note that there are 28 modules in a 2004 Prius HV battery and each one has 6 (1.2 volts each) NiMh "cells" in series. Your Prius monitors them in pairs (14 readings) as all of the modules are connected in series to generate the 200+ volts of the HV battery.
    JeffD
    alexeft likes this.
  3. alexeft
    alexeft Member
    139
    23
    Greece
    Thanks for the answers professor! Nice to know what you said! :)
